Clearly marked jumping points under the bonnet?
Old May 2, 2017 | 07:23 PM
rlvisor's Avatar
Default Clearly marked jumping points under the bonnet?
2016 Jaguar F type R is dead. I found the positive jump point. Are you just connecting the negative to the frame?
Old May 2, 2017 | 07:29 PM
OzXFR's Avatar
You connect the negative lead to the earthing point shown in this pic:
The "bolt" in the lower centre of the pic with the "spiral" bit on top.
Old May 6, 2018 | 08:14 AM
yell03's Avatar
Can I connect my smart charger this way, positive to the positive jump point and negative alligator clip to that bolt?
Old May 6, 2018 | 08:28 AM
mja xkr's Avatar
that's how I connect mine ......
Old May 6, 2018 | 05:48 PM
yell03's Avatar
Thanks, it seems easier than taking the whole back of the car apart.
I pulled everything apart in the back today and it just seems much easier to alligator clip it under the hood.
Do you store that car for over a week this way and it starts right up?
I want to leave my car at our shore home and there might be two week periods of time when we are not there.
Old May 6, 2018 | 07:00 PM
OzXFR's Avatar
See posts 48 to 56 in this thread for an easier way to connect a battery charger to the under-hood charging points (well I reckon it is!): https://www.jaguarforums.com/forum/f...stions-153350/
Old May 6, 2018 | 08:00 PM
ndabunka's Avatar
Do you store that car for over a week this way and it starts right up? I want to leave my car at our shore home and there might be two week periods of time when we are not there.
Thanks for the good chuckle. 2 weeks left un-attended is more like simply "parking" it. No need what-so-ever for a battery tender on it for such a brief duration. I have a couple of cars & have left my R in the garage for a month in the winter without any concern about trickle charging it so you don't really "need" to put it on a charge but on the other hand, it also won't hurt it to do so either so go for it if you like but you also needn't bother if your just planning on leaving it for a few brief weeks at a time.
Old May 6, 2018 | 08:13 PM
Unhingd's Avatar
Originally Posted by ndabunka
No need what-so-ever for a battery tender on it for such a brief duration. I have a couple of cars & have left my R in the garage for a month ... without any concern about trickle charging it so you don't really "need" to put it on a charge ....
+1.
Old May 6, 2018 | 09:25 PM
Suaro's Avatar
For "might be two weeks" I would do nothing. If you were talking about six months in storage I would do the drill. MAYBE a battery manager, if it would help you sleep.
Old May 7, 2018 | 04:54 AM
yell03's Avatar
Thanks, looks clean and functional
I figured Better safe than sorry,
I never know if it will be a longer time and it is over 100 miles away
Maybe I will try not using the smart charger, I also have a jump starter if it won't start.
Old May 7, 2018 | 05:40 AM
RickyJay52's Avatar
In the beginning - over 3 1/2 years ago - I bought a battery tender plus with the intention of using it over the winter. Not only did I not use it but I drove the car throughout the entire winter (enjoyably). Not only that, there were periods where I didn’t drive the car for a solid 30 days - until recently I had 3 other cars - without attaching the battery tender plus, and it never ever failed to start up immediately. In...the dead of winter. YMMV.
Old May 7, 2018 | 07:06 AM
Unhingd's Avatar
It's unfortunate that the F-Type still suffers from the stigma of the early days when the OBD issue was not widely understood and people lost confidence in the ability of the car to hold a charge. It is interesting to see that the Jag techs are still not generally aware of this issue. It would be simple for them to ensure that a car never leaves the shop without being "rebooted".
Old May 7, 2018 | 07:56 AM
yell03's Avatar
That makes me feel better
Actually, this comes from my days of owning Vettes and other newer cars with all the modern electronics, all the little things draining the battery, just a precaution.
Old May 7, 2018 | 10:10 AM
DPelletier's Avatar
....and on the flip side; I installed a pigtail in the trunk making it super easy to plug in the maintenance charger (I think Lance posted the details originally - thanks again!)
These cars are hard on batteries; they have a ton of powered components that don't go "to sleep" immediately when the engine goes off, the start/stop and then the OBD port issue so since there is zero harm in putting the car on the maintenance charger and since I don't drive mine daily, I plug it in always.
YMMV
Dave
Old May 7, 2018 | 10:44 AM
yell03's Avatar
YMMV
Dave
That is my feeling, it can't hurt.
Old May 7, 2018 | 10:46 AM
jv9344's Avatar
Do you guys make any distinction of where the smart key is relative to the vehicle and how often you have to charge/maintain your battery? I understand the car and the key will continually "talk" to each other and prevent the car from going to sleep if the key is in or near the car.
I keep my key at least 30 feet away from the car and use similar charge/maintenance intervals from those above.
Has anyone had any issues leaving the key in the center console and had a dead battery in a week?
Old May 7, 2018 | 11:13 AM
DPelletier's Avatar
If I keep my key in the garage, the car seems to recognize it and not go completely to sleep; in the laundry room on the other side of the door it seems fine.
Dave
Old May 7, 2018 | 02:51 PM
Unhingd's Avatar
YMMV
Dave
Giving credit where it is due, my friend Foosh posted those details. He has now graduated to yet another Vette since he abandoned the F-Type.
Old May 7, 2018 | 04:22 PM
DPelletier's Avatar
A yes, well I'm tipping my glass to Foosh, may he be "vetting about" with a smile on his face. At the same time I'm sure I forgot to thank you for something else along the way so keep it! LOL
Cheers,
Dave
Ali.mb
Nov 25, 2019 07:09 AM
Larry-Cleveland
Apr 30, 2017 03:34 PM
Carl Perkins
Apr 16, 2017 08:33 PM
BOUFFLES
Apr 6, 2017 07:34 AM
82WingNut
Apr 4, 2017 08:35 PM
