Clicking noise after engine shut down
Old Jun 12, 2025 | 12:42 PM
graybeardnw's Avatar
Default Clicking noise after engine shut down
I had the JLR dealer replace the coupler in the supercharger snout and now when I turn off my engine (V6, 46K miles) there is still a kind of klonk-click sound. Below is a link to a short video I made, listen around 10-11 seconds in. I don't know if this is normal or an issue since I've only had the car since last December If anyone has any insight, it is appreciated.
https://photos.app.goo.gl/5SWB7AQRULc1qLnb9
Old Jun 12, 2025 | 01:21 PM
Evoex's Avatar
What did the dealer say?
I wouldn't be concerned personally..but if it wasn't making that sound earlier..
Old Jun 12, 2025 | 01:25 PM
They replaced the coupler twice, and I"m scheduled to bring it back in again on 7/1. The engine running after the second replacement no longer has that "can of marbles' sound so I"m wondering if the coupler is now ok but that sound is just normal?
Old Jun 12, 2025 | 09:55 PM
sov211's Avatar
It sounds perfectly normal to me. It is not displaying the sound of a faulty/failing coupler.
Old Jun 12, 2025 | 10:01 PM
OzXFR's Avatar
Yep, when I had the dreaded worn coupler rattle the shut down clonk sounded a bit different to that of the OP's.
Hard to describe but his sounds "plastic" while the classic clonk is more metallic, and I still get a noise on shut down sometimes which I believe is a relay turning off.
Old Jun 12, 2025 | 11:36 PM
Thanks, so the sound you hear at 10 seconds into the video is what all F6 engines sound like at shut down? Just trying to get a handle on what is "normal' since initially I had the "coupler clunk"
Old Jun 13, 2025 | 11:30 AM
sov211's Avatar
The sound at 10 seconds is not from the engine...it sounds indeed like some sort of relay shutting off. There is no abnormal engine sound. Relax and enjoy this beautiful car.
Old Jun 13, 2025 | 01:22 PM
Lothar52's Avatar
all of the clonks after turning the car off a few seconds are normal on the electronic actuated supercharger cars - does not happen on my early 2010's vacuum actuated superchargers
Old Jun 14, 2025 | 09:58 AM
So I've done a bit more research using perplexity ai and found this article link below where the op provides a video with the exact same sound I have.
https://www.ftypeforums.co.uk/viewto...rce=perplexity
The conclusion on that thread is that it's the ECM calibrates the position of the throttle plate at the beginning of each ignition cycle. When the ignition is turned on or off , the ECM performs a self-test and calibration routine by fully closing the throttle plate and then opening it again. This tests the default position springs and allows the ECM to learn the fully closed position.Just posting here for anyone who searches this article with the same question.
Old Jun 25, 2025 | 12:16 AM
F-type-r-2022's Avatar
Not normal
Old Jun 25, 2025 | 09:46 AM
Originally Posted by F-type-r-2022
Not normal
Huh. So you don't think it's the throttle plate open and closing as a result of the ECM self test?
Old Jun 25, 2025 | 07:42 PM
DJS's Avatar
DJS
Mine does the same thing.
Old Jun 25, 2025 | 11:21 PM
Old Jun 26, 2025 | 07:50 AM
DMeister's Avatar
I occasionally I hear some clicking sometimes with my 2024 R, but it appears to just be coming from the exhaust area cooling down etc…That’s what I assume anyway…
Old Jun 26, 2025 | 09:32 AM
clubairth1's Avatar
Community Influencer
If your concerned can you remove the SC belt and do some tests? It won't throw a code or hurt anything but you will develop a great appreciation for the blower!
Man will the car be a dog without the SC turning!
Does the noise on shutdown change without the belt?
Old Jun 26, 2025 | 05:55 PM
genp729's Avatar
I think it might be isolated to V6 engines, but my 2018 R-Dynamic makes exactly the same sound. I've tested it on the drive with bonnet open and it's definitely the throttle plate actuator making the klunk-click sound on shutdown.
Old Jun 26, 2025 | 07:46 PM
Thunder Dump's Avatar
You might be hearing the electronic valves switching to the open position on shutdown if they are in the closed position when the car is shut off. They make a metallic 'snapping' sound.
Old Jun 26, 2025 | 07:59 PM
Evoex's Avatar
there is definitely clicks that come from the engine back upon shutdown, at least under certain circumstances.
Old Jun 26, 2025 | 08:03 PM
DMeister's Avatar
Absolutely impossible, as the Claws Out mode you so graciously gave me so much fantastic information about when I set it up is literally ALWAYS engaged. Only time it is not is if I’m backing the car out of the garage for just a wash :-)
Brachacz
May 5, 2025 01:58 PM
kiddhan625
Dec 3, 2021 08:49 AM
Henrymccormack83
Nov 27, 2021 10:38 AM
Holy F type
Oct 28, 2019 03:51 AM
chumbers
Oct 7, 2012 05:33 AM
