How much Oil using Drain Hole from Bottom?
Old Jun 26, 2025 | 09:46 PM
Lothar52's Avatar
Default How much Oil using Drain Hole from Bottom?
Drained the oil out of the bottom of my 17 Ftype S AWD.
I know the fill for AWD is 6.5L and RWD is 7.25L, but I would assume those are only for the extraction method using the pipe to the oil pan.
Anybody know the amount for AWD and RWD when emptying at the bottom via the drain hole?
Old Jun 26, 2025 | 10:05 PM
DMeister's Avatar
This has been talked about. Some on here have done both methods to compare and their conclusion was that there like 1 cc oil in the difference in terms of extraction. Basically irrelevant, because there will always be some remaining in the nucs and crannies.
That said, cannot imagine why anyone would want to bother from the bottom when the top method is so dead easy and equivalent.
Old Jun 26, 2025 | 10:08 PM
OzXFR's Avatar
Yep, same amount either way.
Old Jun 27, 2025 | 04:35 AM
Lothar52's Avatar
Originally Posted by ozxfr
yep, same amount either way.
Old Jun 27, 2025 | 06:09 AM
Atipical's Avatar
I just changed my oil last week using the lovely extraction method and got about 6.2L out. More than enough for a maintenance oil change.
Old Jun 27, 2025 | 07:46 AM
OzXFR's Avatar
6.2 litres is about a litre short, either you started with it underfilled by a litre or your extraction pump did not do a good job.
Old Jun 27, 2025 | 08:03 AM
Atipical's Avatar
The max capacity is 6.9L. I measured using the slightly ambiguous electronic gauge prior to draining the oil and I presumed the dealership probably put about 6.5L in - as they conducted the last oil change. I’m not losing any sleep over potentially .3 - .5L left in there.
Old Jun 27, 2025 | 09:30 AM
OzXFR's Avatar
Yep, my bad, I forgot that yours is AWD so 6.5 litres refill not 7.25 litres.
Old Jun 27, 2025 | 11:25 AM
Evoex's Avatar
Burned a bit?
badal38257
Nov 19, 2024 03:48 PM
greenlee63
Mar 2, 2023 10:19 AM
TM1238
Sep 2, 2021 03:35 AM
spanky145
Feb 16, 2020 02:47 AM
Julianj08
Mar 25, 2018 01:51 AM
