Cold start noise
Old Oct 31, 2023 | 03:21 PM
camcam44's Avatar
Default Cold start noise
Hi everyone, hoping someone might have some more info on the noise I’m hearing from my f-type. Mostly on cold starts (under 55 Fahrenheit) I get a noise from the front passenger side super charger area which sounds like a whine that goes high and low consistently for about 5 minutes until the engine is heated (which is why I think it’s belt related). My local Jag dealer did multiple cold starts and said they didn’t hear anything abnormal. It doesn’t affect any driving
systems other than being annoying and loud. Any thoughts would be appreciated!
2017 Jaguar F-Type Premium 340HP11k miles
Old Oct 31, 2023 | 03:27 PM
camcam44's Avatar
Default Audio Attachment
Here is a audio recording of the sound
File Type: mp3
Old Nov 1, 2023 | 02:37 PM
djyankees31's Avatar
I didn't hear anything that sounded concerning.
Old Nov 1, 2023 | 03:50 PM
BruceTheQuail's Avatar
Yeah sounds pretty normal to me. I hate being outside of my car on a cold start, sounds like a tractor
Old Nov 1, 2023 | 04:24 PM
NBCat's Avatar
If they haven't done so already, have the main dealer remove the supercharger and accessories drive belts to determine if the source of the noise if from one of those components.
Old Nov 1, 2023 | 05:17 PM
scm's Avatar
scm
So long as it's a Lamborghini tractor, what's the problem!
Old Nov 1, 2023 | 05:45 PM
OzXFR's Avatar
I can hear a slight scraping noise. Quite rhythmical and around once per second.
Not normal and not a sound I have heard before.
Maybe it's just the "whine" going up and down in pitch, maybe it's something else.
From the description I thought it could be the infamous SC coupler/torsion isolator rattle but it's not that.
My best guess is a worn SC bearing or SC belt tensioner or worn SC belt idler pulley, with SC bearing at the top of the list. My next suspect would be something driven by the accessory belt, either that thing itself or a bearing inside of it, eg the AC compressor or the alternator
As the first of these are SC related I would do as NBCat advised but with a slight variation - remove the SC belt first and see if the noise goes away, if it does then you have narrowed it down to something related to the SC, if the noise persists then put the SC belt back on and remove the accessory drive - "serpentine" - belt and check again. Also, before and after removing either belt, try using a car stethoscope to see if you can narrow down the source/cause of the noise.
Old Nov 1, 2023 | 05:48 PM
OzXFR's Avatar
Have you been watching Car Wizard????
He just bought a 1969 Lamborghini tractor, it's a two cylinder which is only running on one cylinder and it sounds pretty damn rough!
Old Nov 2, 2023 | 04:24 AM
scm's Avatar
scm
Not seen that one, my info comes from the excellent Iain Tyrrell channel. Rumours of them using a Ferrari clutch seems to be not entirely untrue!
carzaddict
Nov 7, 2023 12:25 AM
asjdhsajhdfj
Jan 13, 2023 03:31 PM
asjdhsajhdfj
Mar 15, 2022 08:20 AM
Noxparadise
Dec 29, 2013 08:37 PM
TRidder
Oct 3, 2011 03:58 PM
