Confused with CCMs
Old Oct 1, 2019 | 03:26 PM
rj3's Avatar
rj3
Default Confused with CCMs
I have 23k miles on my 15 V8S with CCMs. I've looked around the forum but am still a little confused with upkeep of the brakes.
How often do I have to change the pads? I don't track the car and it sees only city/highway driving. I saw somewhere that they should be changed every 25k miles but at a cost of $2500 for a set of pads, thats almost $10,000 in pads over the lifespan of the rotors (100k miles). At this point would I be better off selling the CCMs and putting on regular steel brakes?
Thanks!
Old Oct 1, 2019 | 04:38 PM
OzXFR's Avatar
See this thread and especially post # 3: https://www.jaguarforums.com/forum/f...carbon+ceramic
Old Oct 1, 2019 | 05:01 PM
rj3's Avatar
rj3
Thanks! This thread talks a lot about the rotors but I can't find a clear answer to pads. Is it fair to assume that they should be changed with 50% wear? Right now I believe the rear pads are down from 10mm to 8mm which means I do have some time left but don't want to wait too long as I risk damaging the pricey rotors
Old Oct 1, 2019 | 05:13 PM
OzXFR's Avatar
The minimum thickness for the front pads is 3 mm and it's odds on the same 3 mm for the rear pads, so yours are barely worn at all and way short of needing replacement.
Nothing to panic about!
cohibarandy
Sep 28, 2019 04:05 AM
jagxkrtoofast
Oct 3, 2017 09:36 AM
IMMD
Aug 28, 2017 05:35 AM
Bcrary3
Apr 14, 2015 12:47 PM
concertoed
Sep 11, 2012 08:02 PM
