Coolant pipe replacement - Parts sources
Old Oct 24, 2025 | 10:14 AM
62jeff's Avatar
Default Coolant pipe replacement - Parts sources
Greetings,
I'm starting to plan out replacement of the plastic cooling pipes, etc. on my 2014 V8. There are numerous threads on the topic of the pipes and I've been perusing them.
Cutting to the chase though - is there a preferred source for the metal components, or a kit that includes all gaskets and other bits I would need? Or a thread that discusses this you can point me to more directly?
Thank you,
Jeff
Old Oct 24, 2025 | 11:03 AM
CarlB's Avatar
The actual OEM JLR aluminum would be my suggestion.
Old Oct 24, 2025 | 11:29 AM
62jeff's Avatar
I'm finding the two JLR pipes referenced by CarlB, but also finding a kit from EuroAmp that looks pretty complete. 10-14 Jaguar Land Rover Cooling System Upgrade Kit V2 5.0 V8 Superchar — Euro AMP
Old Oct 24, 2025 | 12:21 PM
harryf's Avatar
Here was what I posted in the F-Type Owners Club Facebook Group:
Here are the official part numbers: (I didn't put the V6 info on this as it only applies to the V8)
- LR186917: Lower pipe (aluminum) 9W83-8A520-EA
- LR186859: Upper pipe (aluminum) 9W83-8A504-HA
- C2Z18658: Water pump connector(aluminum)
- T2R5910: Coolant reservoir water pipe
- AJ811576: RH inlet manifold gasket (v8)
- AJ811590: LH inlet manifold gasket (v8)
- C2Z28265: Throttle body gasket
- C2Z19929: Thermostat (v8)
- C2Z28258: Revised thermostat outlet hose (with brass elbow) (V8)
- AJ813909: Water pump
By the way the LR parts are from Land Rover. Not sure if they've now have Jaguar part numbers yet.
Hope this helps.
Old Oct 24, 2025 | 12:53 PM
62jeff's Avatar
Originally Posted by harryf
Here was what I posted in the F-Type Owners Club Facebook Group:...
Hope this helps.
Excellent, thank you!
Old Oct 24, 2025 | 06:42 PM
Craaaazzy's Avatar
I’ve used Euroamp’s kit and had no issues with it. From what I remember, they had a bad batch of coolant pipes but those should be fixed now.
Old Oct 24, 2025 | 07:04 PM
texas jag's Avatar
I’ve got a ‘14 V6S, and used the EuroAmp kit. No complaints from the indie that did the work. While you are at it, do the supercharger oil, coupler and belt. They are essentially freebies other than parts cost.
Old Oct 24, 2025 | 10:11 PM
dennis black's Avatar
20 Year Member
Doesn't matter where you get it
Tomwhite
Apr 16, 2026 10:44 PM
Tamaren
Jul 24, 2024 07:16 PM
silvertonesx24
Sep 10, 2023 10:30 PM
gershon
Jul 24, 2023 06:40 PM
ufok
Jun 22, 2023 09:47 AM
