Door handle Inlay - lettering wearing off
Old Feb 19, 2023 | 10:02 AM
PilotR's Avatar
Default Door handle Inlay - lettering wearing off
Hello everyone, small cosmetic issue i have, is that the lettering on the drivers side of the door handle is wearing off. I am probably not the only one with this issue.
I assume that the insert cannot be purchased seperately? Anyone any suggestions?
Thank you
Popular Reply
Jun 25, 2023, 03:58 PM
PilotR's Avatar
PilotR
Ok, I took the time today to work on the car.
With rebrushing the aluminum I ment using the scotch pads I have to brush my watch bracelets (I am a watch enthusiast as well) in case of scrathes or refinishing. That is also the easiest way to get the rest of the lettering off.
The refinished handle looks like this (sorry car is dirty):
I ordered brake caliper decals in different sizes. I used the smallest which is a tiny bit larger than the original (I like it better though), side by side they look like this:
And this is the finished result. Make sure the surface is absolutely clean for the application:
I really like the end result. I actually like the slightly larger lettering better than the original one. That is though highly depending on your taste.
Old Feb 19, 2023 | 06:56 PM
Carbuff2's Avatar
"Duct tape fixes anything"?
Perhaps, more seriously, use a layer of that aluminum duct sealer tape (don't cover the KEY icon) then use the Jaguar lettering that folks apply to their brake calipers.
Once you 'restore' the lettering, ask a detailing shop for a piece of leftover PPF (Paint Protection Film) to prevent it from wearing off in the future.
Old Feb 19, 2023 | 07:53 PM
lizzardo's Avatar
I had to check mine after seeing this. They're fine.
Oh, and your shoe's untiled
Old Feb 19, 2023 | 08:39 PM
MK18's Avatar
I had the same issue. I bought used and the "AGU" was almost completely gone. I just removed the remaining letters so it didn't look so worn, rather than a "J AR"
Can't see it when locked or driving, and I don't need the door handle to remind of the my car manufacture.
Also, get the cool leaper or growler puddle lights to distract . . .
Joking aside, I would restore mine too, if there is a quick, cheap, and clean fix.
Old Feb 22, 2023 | 04:39 PM
Whatsnext's Avatar
The first F Type I saw used for sale at a local deal had this issue. It was a 2015 with under 30k and the lettering was almost completely gone. I wonder if this was another issue with earlier models similar to the issue with the interior sticky button issues. What year is your F Type? Mine is a 2016 and no issues yet but still very low mileage-18k.
Old Feb 22, 2023 | 04:56 PM
MK18's Avatar
I have a 14. It is probably related to how you grab and pull the handle. If you grabbed the handle the way, the OP did in his picture, I’m sure you would be fine throughout the years. A thumb over would probably start to wear faster.
Old Feb 22, 2023 | 06:43 PM
OzXFR's Avatar
I have a MY2015 built Oct 2014 and there is zero wear on the driver's door handle including the Jaguar script.
And it's a year round daily driver so that handle gets plenty of use.
But I don't even touch that script area let alone rub my thumb over it.
Old Mar 19, 2023 | 09:53 AM
PilotR's Avatar
The approach that I went with is rebrushing the aluminum trim there (which I already did for the driver side). The finish is really good now with the fresh brushing. I ordered different sizes of the Jaguar Logo to see what fits best. I ll post the result here in this thread.
Old Mar 28, 2023 | 02:25 PM
kevin_jag's Avatar
Mine is like this on only the passenger side, which was interesting to me because naturally the driver's door gets opened and closed more often, probably, right? I made a theory that the driver's partner/passenger maybe had painted nails or longer finger nails, which forced them to use their thumb and pointer finger knuckle to operate the door handle in order to protect the nails, leading to the wear.
Who knows though! But I would also like an easy fix, tho I may consider just removing all together. How does one go about doing that?
Old Mar 28, 2023 | 05:55 PM
OzXFR's Avatar
Acetone will get it off for sure but it doesn't play nice with plastic so I wouldn't recommend it!
IPA (Iso Propyl Alcohol) on a MF cloth will probably work without any problems.
Old Mar 28, 2023 | 06:39 PM
Borbor's Avatar
Have you determined the cause of the wear.
If it is mechanical ie rubbing on guide or similar on inside of the door then replacing with another overlay will just wear off again unless you sort out the original friction point
or more unlikely do you think it is someones/your other half's thumb rubbing it off. In that case serves you right for marrying a concreter.
Old May 21, 2023 | 11:15 PM
Simdeity's Avatar
PilotR - what do you mean you re-brushed the aluminum? Did you paint the Jaguar logo back on? Or use a label?
Old Jun 25, 2023 | 03:58 PM
PilotR's Avatar
Old Jun 25, 2023 | 04:25 PM
mcphill's Avatar
Nice job!
Old Jun 25, 2023 | 04:52 PM
PilotR's Avatar
Thank you.
Considering the people questioning where does this come from. It is clearly the use of the handle that makes the lettering dissappear over time.
If you are grabbing the door handle by the aluminum surface the printing will rub off eventually. Which is something that some owners do, because they are grabbing the handle as an oldschool handle.
Especially older people tend to do that.
The only way to get that logo 100% bulletproof is to laser engrave it, but I guess that was a bit too much for Jaguar to do.
Old Jun 25, 2023 | 05:29 PM
scm's Avatar
scm
That's a bit ageist - I'm in my 70s and certainly don't hold the handle like that.
Old Jun 26, 2023 | 09:41 PM
Valerie Stabenow's Avatar
PilotR .. great job!
did you mask off the area around? Where did you get your caliper decals? How did you avoid the little key emblem?
Old Jun 27, 2023 | 07:16 AM
PilotR's Avatar
I did but only for the brushing to not scratch the paint. You just use normal tape. You just cut a small piece of the scotch pad and brush in the same direction as the original brushing. The lettering will go right off, its not really well printed. That way you wont hit the key printing.
The caliper decals I got from etsy.
Shop is called caliper stickers:
www.etsy.com/en-gb/listing/1038566326/jaguar-2020-brake-caliper-decals
MajorTom
Sep 17, 2022 04:30 PM
dborthwick
Oct 13, 2018 10:39 AM
G1983
Jan 23, 2011 10:32 PM
XJ6_1994_J40
XJ40 ( XJ81 )
Jun 2, 2008 12:47 PM
