Driver airbag error code B0020(1A)
Old Apr 24, 2025 | 04:39 PM
ufok's Avatar
Default Driver airbag error code B0020(1A)
Good day Lads,
recently while driving my F-Type I noticed that the airbag light comes up within a few minutes of starting the car. I checked the code and it seems to be B0020(1A) - Left Side Airbag Deployment Control: Circuit Resistance Below Threshold.
The airbag light comes up around 80-90 percent of the time. What is interesting, even if it does not come up, once I leave my seat when the car is idling, the airbag control will appear immidiately and won’t go off after I get back behind the wheel.
Do you know if there are any connections for the airbag system under the seat?
Old May 13, 2025 | 05:33 AM
ufok's Avatar
Today I disconnected the battery and removed the airbag.
after unplugging all the connections, I sprayed them with an electric contact cleaner and checked the condition. Two connectors seem a bit burnt. Do you think that they might be responsible for the B0020 fault? I do not know, how to diagnose the issue further with a multimeter.
After the cleaner dries out, I will re-connect the pins, the battery and check for the airbag fault again.
Old May 13, 2025 | 09:13 AM
Thunder Dump's Avatar
Seems like an unusual amount of corrosion around that blue electrical plug where there shouldn't be any. Was this vehicle a flood vehicle or in an area of high humidity?
Old May 13, 2025 | 10:12 AM
ufok's Avatar
yes, the car was driven in Texas near Houston, hence the rusty spots.
I did some more digging and realized that the B0020 error is not for the Steering Wheel, it is for the side airbag in the Seat! Omg, now I need to remove the whole seat and troubleshoot inside. Any ideas on how to tackle this?
JoonasJaguar
Jul 20, 2024 06:28 AM
Phil m
Jul 8, 2024 06:05 PM
sashoivanov78
Feb 1, 2014 03:12 PM
apollo022777
Apr 16, 2008 07:56 PM
