F-type door fit
Old Feb 19, 2018 | 05:47 PM
powerhouse's Avatar
Default F-type door fit
Seems to be a lot of owners have had problems with the door alignment, mostly on the passenger side, picture below is a new car in a showroom, has anyone encountered this and was it a quick dealer fix. Doesn't seem to be great quality control.
Old Feb 19, 2018 | 06:54 PM
DJS's Avatar
DJS
I'd make sure it isn't closed on the seatbelt - that does look lousy.
Old Feb 19, 2018 | 08:01 PM
shahuk's Avatar
I had this issue it looked exactly like that. I booked it in at the dealer and when I turned up they fixed it in 5 minutes - they didn’t even check the car in. It was an adjustment to the latch on the frame that catches the door when it closes. Looks much better now
Old Feb 19, 2018 | 08:36 PM
OzXFR's Avatar
Good tip.
The bottom edge of my driver's door (so RHS) sticks out about 3 or 4 mm from the bottom panel/rocker, at the rear only. It's not real bad and I doubt if anyone else will ever notice it, but it still annoys me.
So I loosened off the two bolts which hold the door latch on - standard 6 point Torx T40 - and had a fiddle. There is a surprising amount of movement available, both fore and aft and up and down.
Bottom line - every adjustment I made just made the door fit everywhere else worse, and the best fit was exactly where it started, so that's where I ended up!
Not to mean though that this adjustment won't help others get a better fitting door.
Old Feb 20, 2018 | 11:57 PM
domino_z's Avatar
yep i have the same problem - it's only seemed to be more apparent in last few months, so ill take a look at the latch adjustment
though i can't fathom how that will help as the door everywhere else fits perfect - in terms of where it sits at top edge against rear fender and panel gap to front fender
Old Feb 22, 2018 | 04:11 AM
jaguny's Avatar
I brought the issue of having some water get inside the car onto the sill area when washing the car. My dealer said this condition of door is "normal".
Old Feb 22, 2018 | 07:29 AM
mc5mojo's Avatar
My drivers door is like this. I took it to the dealer, they said they looked at the latch and said there was no adjustment. If I wanted it to fit better take it to a body shop.
After they told me that I looked at almost every F Type on the lot and pretty much all of them have a door like this.
Old Feb 22, 2018 | 08:03 AM
palmlakesman's Avatar
I had the same issue. My dealer sent it to their body shop. They said they adjusted the rocker panel. Looks much better now!
Old Feb 22, 2018 | 04:02 PM
OzXFR's Avatar
Yep, it became obvious to me when I adjusted the door fit by moving the latch that the only way to get the door to fit right and reduce or eliminate the bottom gap would be to fiddle with the fit of the rocker panel. So the problem is the rocker panel fit, not the door fit.
Does anyone know how to do this easily, or do you have to remove the thin aluminium treadplate which apparently is damn near impossible to do without destroying it?
Old Feb 24, 2018 | 07:48 AM
jaguny's Avatar
Can you post a photo? Great if you had before and after?
Old Feb 27, 2018 | 07:11 PM
IlMostro796's Avatar
Mine is like that. I need to make a list of things to tell the dealer.
Kopi
Dec 21, 2014 04:22 PM
Mmutch
Dec 28, 2013 06:48 AM
TomServo
Jan 18, 2012 05:10 PM
jagosaurus
Aug 23, 2011 03:10 PM
kevinsuk
May 30, 2011 06:54 AM
