F-type R stock boost curve
Old Apr 30, 2016 | 07:08 PM
cbroth1's Avatar
Default F-type R stock boost curve
Hi All,
I was wondering if any of you F-type R enthusiasts have logged the boost while running your stock file or tune on the stock pulley. I'm only managing to reach 9.0-9.5 psi max by reading the PID output from the MAP sensor and correcting for atm pressure. Seems low. Data is appreciated! Thanks.
Old Apr 30, 2016 | 07:30 PM
Unhingd's Avatar
Originally Posted by cbroth1
Hi All,
I only have that info for a V6S (stock and tuned) if anyone is interested.
Old Apr 30, 2016 | 07:48 PM
Smoke Em's Avatar
Unhinged. I am interested as we basically have the same car except I have the auto.
Old Apr 30, 2016 | 10:02 PM
Unhingd's Avatar
I'll forward tomorrow.
Old May 1, 2016 | 09:40 AM
cbroth1's Avatar
I'm interested as well given that the supercharger is the same. Some insight could be gained from the boost vs power relationship on the V6.
Old May 1, 2016 | 09:41 AM
Foosh's Avatar
I thought so too, initially, but I think it's been established that the V6 and V8 blowers are different.
Old May 1, 2016 | 10:00 AM
cbroth1's Avatar
I know the part numbers are different, but I couldn't find any info as to whether that means the OEM case is different, or that the actual blower displacement is smaller. I always thought that the TVS 1740 would make more sense on the V6.
Old May 1, 2016 | 10:49 AM
Tuning@VelocityAP's Avatar
The 3.0L supercharger is different, same style TVS, but a smaller displacement. (smaller casing, smaller rotors)
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old May 1, 2016 | 11:01 AM
cbroth1's Avatar
Well, I'm glad to hear that, because using the TVS 1900 on a 3.0L motor never made any sense to me.
Old May 1, 2016 | 11:11 AM
No worries, I'm 100% on this...there both sitting on the shelf in front of me! :-)
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old May 1, 2016 | 11:21 AM
Unhingd's Avatar
The V8 is an Eaton TVS R1900
The V6 is an Eaton TVS R1320
Old May 1, 2016 | 01:17 PM
cbroth1's Avatar
Pics!? Please.
Old May 1, 2016 | 03:25 PM
Smoke Em's Avatar
thank you
Old May 1, 2016 | 04:18 PM
Unhingd's Avatar
thank you
OEM Tune
Current Tune
Old May 2, 2016 | 10:34 PM
domino_z's Avatar
unhingd what software/hardware are you using to log?
Old May 2, 2016 | 11:05 PM
Unhingd's Avatar
Dynapack dyno and software.
Old Dec 22, 2021 | 08:35 PM
hammam almulhe's Avatar
Default Methanol boost pressure sensor
OEM Tune
Current Tune
hey unhingd. I have a methanol kit. Going with 4 port injection through the plenum. However, i an not sure where i should connect my kit’s boost sensor for injection reference. Do you think there is any other location to fit it other than tapping into the SC plenum?
Old Dec 22, 2021 | 10:20 PM
DJS's Avatar
DJS
Several people have added meth setups - have you searched the forum? Note this is a 5-year old thread. Many of the posters aren't here anymore, though Unhingd is occasionally.
Old Dec 23, 2021 | 08:11 AM
Therock88's Avatar
What type of controller do you have? Based on your question, I assume your reference is a hose and not an electronic/electrical signal? I put an entire DIY on this forum as well, with lots of information.
If you are triggering from a vacuum, most tap the plenum, but really any variable vacuum will work as you are just looking for a relative change (i.e. it does not matter if it is 1 - 5 units or 4 - 10 units...Just a relative trigger of when to start spraying and when to max it out - assuming you are using a variable controller, which I recommend).
Below is where another member tapped in for a reference. You have to remove the cover to drill for your nozzles anyway (you do NOT want to put them in the intake tubes in front of the TB).
DC
tec-9-7
US Northwest
Dec 27, 2020 11:58 AM
djyankees31
Oct 17, 2019 11:15 AM
LaCroix
Aug 12, 2019 04:44 PM
Dremorg
Aug 2, 2015 11:27 AM
Cambo
Dec 20, 2013 02:23 PM
