FR500GT's F-Type Build Thread
Old Feb 4, 2018 | 01:01 PM
  #141
Chawumba's Avatar
Silver and black theme looks fantastic, way to keep pushing the limits...
Old Feb 5, 2018 | 09:26 AM
  #142
jrodrg's Avatar
Are you going to have to disable the stock rear ring once the aftermarket one is on?
Old Feb 5, 2018 | 11:34 AM
  #143
njmadgenius's Avatar
Awesome build and totally exciting to watch... I've built some less expensive cars over the years including a ground up turbo Miata. My SVR leaves me with very little left to desire but maybe over time I might find some things I would like to change. I agree the R and SVR have ample power as mine can easily break all four loose when you drop the hammer on it.
Old Feb 6, 2018 | 01:26 AM
  #144
FR500GT's Avatar
Thanks guys
Yes. I will be disconnecting the plug underneath the rear trunk hatch so that the wing no longer deploys at 70mph.
Old Feb 6, 2018 | 01:45 AM
  #145
zmoothg's Avatar
The thread is awesome. I will reach out to you next time I am in LA. The body shop is estimating that my car will completed by the end of Feb. Was able to order the SVR bumper and add an Eventuri intake on to the car. Looking forward to see how it sounds once I get the car back. Loving your car.
Old Feb 6, 2018 | 01:50 AM
  #146
OzXFR's Avatar
Originally Posted by FR500GT
Thanks guys
Thanks for that, I had no idea what a "stock rear ring" was, now I know it was meant to be "stock rear wing" (ie spoiler).
See here for how to do it: https://www.jaguarforums.com/forum/f...7/#post1614196
Old Feb 6, 2018 | 11:55 AM
  #147
FR500GT's Avatar
Sounds good man
Yessir, I had that thread saved and was planning on using it!
Old Feb 12, 2018 | 06:38 PM
  #148
FR500GT's Avatar
ClearPlex Installed on the Windshield
As the track season approaches, it was time to ClearPlex my windshield. I was out at Chuckwalla this weekend with my brother for Bimmer Challenge and the amount of rocks and rubber that got kicked up at his M3 made me install the Clearplex first thing at work this morning. If you don't already know what it does, it's essentialy a clear bra for the windshield. We used the ClearPlex IR which has 70% tint (barely noticeable) and also helps cut down on heat. A good installer will get this installed on the car so that it looks like nothing is even there... as you can see in the last two pictures.
Attached Thumbnails FR500GT's F-Type Build Thread-5adf4cb3-4b50-4fe9-b816-54fb93740039.jpeg   FR500GT's F-Type Build Thread-e94f0375-01ce-4501-8548-66b174efe17f.jpeg   FR500GT's F-Type Build Thread-d56057dc-dd9d-4b09-a751-1593c66b36d0.jpeg   FR500GT's F-Type Build Thread-ec2c3270-d929-470e-aee6-9597d1c6c459.jpeg   FR500GT's F-Type Build Thread-01a26305-d0b2-4048-9cd3-75fc537b71f7.jpeg
Old Feb 16, 2018 | 02:09 PM
  #149
FR500GT's Avatar
GT Carbon Wing Installed
I've had this carbon fiber wing just sitting in my office since last summer and I finally had the time last week to install it. Unfortunately like the rear diffuser, this wing was ordered online from a random company and has its imperfections but I plan to wrap it black anyways. A few people have PM'd me in regards to the install, plan out for an hour or two depending on what tools you have readily available. Most of the tools are common, but you will need a TS27 Torx. Here it goes:
1. Disconnect the connection for the auto wing. For this step I used OzXFR's write up (post #133):https://www.jaguarforums.com/forum/f...7/#post1614196
2. During the above removal process you can use that time to mount the CF wing to the factory wing once it is removed from the car.
3. Start by making templates out of masking tape from the bottom of the CF wing and then transfer them to the factory wing. (There's not much room to adjust except an inch or so front to back).
3. Measure it again.
4. Measure it yet again.
5. DRILL 4 HOLES INTO THE FACTORY WING. YEP.
6. Make sure you drill all the way through both panels.
7. Go back and make the holes on the underside panel bigger (enough room so the heads of the 4 supplied bolts will drop through them) This allows for the factory wing to sit flush when reinstalled.
8. Install all 4 bolts and take your time to make sure you don't over tighten them and potentially crack the carbon fiber.
9. Cover the exposed bigger holes with rubber grommets for a clean look.
10. At this point the CF wing and factory wing are essentially one unit and are ready to go back on the car!
11. Complete the rest of the steps in OzXFR's writeup on step 1.
12. Go for a drive and make sure the wing doesn't come up at 70mph (It shouldn't).
A few people were wondering if any dash lights come up now that the rear wing motor is disconnected and the answer (at least what I found) is that a light stating Spoiler Not Available will come up at 100mph and above. At this time if you currently have your Traction Control off, it will automatically turn it back on. Overall I am pretty happy with the CF wing but still plan to paint or wrap it black in the next couple of weeks.
Attached Thumbnails FR500GT's F-Type Build Thread-900bdcab-70c0-40a0-a751-87e3fb1f5a06.jpeg   FR500GT's F-Type Build Thread-9579ca3d-0e43-498e-88c7-db5a583ec4a3.jpeg   FR500GT's F-Type Build Thread-82b43eee-5c5d-4757-96b6-aa250715b6b5.jpeg   FR500GT's F-Type Build Thread-0a0cdffb-90ad-4cb3-a3d5-d56deee99bcb.jpeg   FR500GT's F-Type Build Thread-514e3d48-1936-4d95-83df-3930fe2f2d2b.jpeg
FR500GT's F-Type Build Thread-dab8a7b3-21a7-4485-b182-9578f3c65b11.jpeg   FR500GT's F-Type Build Thread-c5382e55-7c74-4258-b89d-49846c395079.jpeg   FR500GT's F-Type Build Thread-079f619e-0f60-49f3-ac2d-7ebec0a787a1.jpeg   FR500GT's F-Type Build Thread-3e8b7908-d562-4c72-a26f-ba01fd58cf03.jpeg   FR500GT's F-Type Build Thread-dc9a8f88-ebe4-46ab-9fb4-47783bd295de.jpeg
Old Feb 16, 2018 | 02:56 PM
  #150
zmoothg's Avatar
Looking awesome. I love how there is a centenario just hanging out in the background. So you are planning to wrap the CF wing black?
Old Feb 16, 2018 | 03:31 PM
  #151
FR500GT's Avatar
Yeah, both the wing and the rear diffuser.
Old Feb 16, 2018 | 06:04 PM
  #152
IronMike's Avatar
The Clearplex appears to have a prominent blueish tint.
Is that true, or just the angle of the pictures?
Would you mind sharing what this might cost a fellow F-Type owner?
Old Feb 16, 2018 | 08:54 PM
  #153
mshedden's Avatar
Recently someone detailed fitting a CF replacement factory style 'wing', where, as part of the procedure, the factory 'wing' was separated into its 'inside' and 'outside' parts (held together with 3M style tape) using a heat gun. Presumably, you could have done that and had no holes drilled in the factory 'inside' panel, leaving it pristine... yeah, too late...
Old Feb 17, 2018 | 12:00 PM
  #154
FR500GT's Avatar
It’s a mix of a few things; the ClearPlex IR has a slight 70% tint to it versus the non IR, the 2017+ F Types have the radar (or whatever you call it) windshields that produce a slight blue hue from the factory, and lastly yes I think the angle and lighting of the picture makes it look bluer than it really is haha. I’ll take a few more pictures of it outside in the sun.
The cost to do ClearPlex on an F-Type runs $475.
Yep, thought about that prior to starting this. The heads of the 4 bolts wouldn’t allow for the factory wing to lay flat.
Old Feb 23, 2018 | 03:07 PM
  #155
FR500GT's Avatar
My car will be out front at our Cars and Coffee tomorrow morning. I look forward to seeing some of you guys again!
Here's a video of our Open House last October:
Old Feb 23, 2018 | 06:32 PM
  #156
Chawumba's Avatar
I'll be there. Might have my E90 M3 with me, I'm thinking about a wrap for it and wanted to get info...
Old Feb 23, 2018 | 06:50 PM
  #157
abhishriv's Avatar
where did you purchase the ClearPlex? I want to get some as well and get the local PPF installer to do it for me... they don't carry ClearPlex themselves for some reason.
Old Feb 24, 2018 | 03:17 PM
  #158
Chawumba's Avatar
Best Cars and Coffee I've been too! Lambo's, Ferrarri's, McLarens, and Porsches galore. Even a P1, couple bugatti's and a 918 for on display. Not to mention the stylish silver F Type with awesome rear wing.
Great group of folks, awesome sponsors, great cars. Only one question, why do some dork's always feel the need to excessively rev engines and do burnouts near these events???
Old Feb 24, 2018 | 06:56 PM
  #159
FR500GT's Avatar
Stop by the shop next week and I’ll give you a tour and we can go over some ideas!
It’s possibly that like PPF, you have to be a certified installer but I’ll ask on Monday if it’s possible for us to get you the product.
Haha yeah it was a pretty good turn out today. And yes, I agree, unfortunately no matter what show it is or what you tell people, there will always be a few people that will do whatever they think is cool. Luckily, compared to most events in So Cal as of late, it wasn’t too bad this time.
Old Feb 25, 2018 | 08:02 PM
  #160
FR500GT's Avatar
All clean before yesterday’s event. The side vents are now black as well (was done after that first picture was taken).
Attached Thumbnails FR500GT's F-Type Build Thread-85b7b79c-f56c-451a-bb85-06bbae1bcdcb.jpeg   FR500GT's F-Type Build Thread-0cc9226f-3117-4235-8911-bbf585fab50b.jpeg
