Is this gap normal for our cars (photo inside) ?
Old May 17, 2020 | 03:21 AM
Nznoonee's Avatar
Default Is this gap normal for our cars (photo inside) ?
Hi, one thing has recently drawn my attention about left door of my F-Type.
Photo below. It's noticeable that it's not flush with the body, when closed.
Am I being paranoid or this is not OK ?
Does anybody have this? The thing is right door looks better
Mileage is 18K, and I'm the second owner.
Old May 17, 2020 | 03:58 AM
OzXFR's Avatar
That is not right.
But it should be an easy fix.
On the door jamb / B pillar is a U shaped latch (with a little kink in it), held on by two Torx T40 bolts.
Loosen those bolts off and push the latch in a tad, I guess about 2 mm in your case.
Tighten the bolts back up again, shut the door and check.
Rinse and repeat as needed until it is as good as you can get.
Old May 17, 2020 | 04:03 AM
Nznoonee's Avatar
Originally Posted by OzXFR
That is not right.
Thanks! But does it mean that the door was taken off for some reason?
Old May 17, 2020 | 04:12 AM
OzXFR's Avatar
Maybe, maybe not.
It could have come from the factory that way, lots of reports of ill fitting doors and panels on new F-Types.
Old May 17, 2020 | 05:40 AM
linklaw's Avatar
My 2016, which I bought with 2000 miles on it, looks like that on both doors. My friend who is an auto body tech says that's the way they put them together at the factory. It should be relatively simple, as described above, to correct the gap.
Old May 17, 2020 | 05:04 PM
powerhouse's Avatar
Its not an f type if it hasn't gaps, I don't even know if they bother checking alignment sometime, from doors, bonnets, even the boot lid, its the norm, don't panic about it,
The picture below is the jaguar engineers testing new panel alignment techniques
Old May 17, 2020 | 08:09 PM
Unhingd's Avatar
That headlight bonnet would be really cool if it wasn’t so damn ugly.
Old May 17, 2020 | 09:07 PM
HalcyonDays's Avatar
Both my doors looked like that and the bonnet needed aligning as well, when I purchased my most recent F Type. Took less than an hour for the bodyshop to make it right. I've read that it is a do it yourself fix. I took it in since it was recently purchased new.
Old May 18, 2020 | 03:19 AM
Nznoonee's Avatar
Thank you guys! I was really paranoid thinking my car was in an accident before. Also, white color makes all the gaps more visible.
1989xjs
Feb 17, 2020 08:57 AM
powerhouse
Feb 27, 2018 07:11 PM
jagtoes
Dec 26, 2017 04:25 PM
steve_k_xk
Mar 21, 2016 08:22 PM
jmfan
Oct 2, 2014 12:43 AM
