Get that Y-pipe done!
What size do I need? Thinking M6 x 20 or 25mm, maybe get some washers just in case?
From this video he mentioned 20 mm:
https://youtu.be/JaPCktESH8A?si=on_Lnmyh1VVT7KE2
The later plastic ones also have the small tab and require a shorter bolt, I usually cut down one of the old water pump bolts to a suitable length so the head matches the rest of the bolts.
1) Block the port on the back of the SC (that part number above I think)
2) Leave the solenoid wired up, not sure what you did to keep things tidy and secure there
3) Cap the vacuum lines
4) Block off the cabin tube
Anything else?
Thanks,
Brad
Hey Robtrt8 - quick question if you don't mind, AJ813002 symposer plug, is this actually what's needed to delete the symposer altogether? From what I've researched to remove the symposer I need to:
Anything else?
Thanks,
Brad
Anything else?
Thanks,
Brad
Much appreciated guys, so did you guys use the official JLR cap or did you fabricate your own?
I used the VAP one since I had ordered a bunch of stuff from them. I 3d printed a cap for the cabin tube and solenoid output. You can get a regular vacuum cap from you local autoparts store that will do for the solenoid output though.
simoriah
Feb 1, 2026 04:04 AM
amwalters
Apr 29, 2023 05:07 PM
