Guide: Front wheel slat install on PPF
Old May 6, 2026 | 03:57 PM
DMeister's Avatar
Originally Posted by cpq100
I also have the double sided tape in addition to the clips. I do have the PPF on the inside of the wheel well edge.
Oh, okay, so to be clear…You ran extra tape the length of the slat like I did? Or you only used the tape that came on the bottom of the slat only?
Just curious.
Old May 6, 2026 | 04:23 PM
cpq100's Avatar
I ran the tape the entire length of the slat.
Old May 6, 2026 | 04:29 PM
DMeister's Avatar
Okay, appreciate the clarification. Makes sense now ;-0
Old May 6, 2026 | 05:12 PM
Portlander's Avatar
The clips we're using are not meant for the F-Type which may be why they are not snug enough when applied over the indentations. The factory splats on the rear of the F-Type are molded onto the body and are clip free. Is it possible that the sheet metal on the XJR is a little thicker than the F-Type around the wheel wells which may be why the clips are not gripping as tight (indentations) as they should?
Old May 6, 2026 | 06:37 PM
DMeister's Avatar
I tend to think if I didn’t have PPF that is slippery it might have been fine? But clearly you were in a better position to gauge that in not having PPF. It makes some sense for sure, because yeah, there is quite a difference in thickness in and outside of those marked locations.
Old May 6, 2026 | 08:05 PM
Portlander's Avatar
Well, the good news is the splats are affixed securely to our cars through what ever means necessary. They will provide some protection and I think it gives the front fender a finished look.
Rob Schwartz
Aug 8, 2025 12:16 PM
brinny
Jul 10, 2025 11:54 PM
Jrizzo003
Apr 20, 2024 10:34 AM
tjankovs
Oct 6, 2021 07:52 PM
hafren
Jan 3, 2017 09:59 PM
