H422: Fuel Vapor Purge
Old Jun 21, 2024 | 09:34 PM
cpq100's Avatar
Default H422: Fuel Vapor Purge
Just received an email from my JLR Dealer. My 2018 R-Dynamic needs prompt attention to perform open service action H422: Fuel Vapor Purge. It will be performed at no cost to me. All I have been able to find is it is a software update.
Does anyone have information on this software update?
Old Jun 22, 2024 | 03:43 PM
Blacks18's Avatar
I also just received this email, curious as well to see if this is something I need to do, since I’m not a fan of software updates from the dealer lol..My car is also a MY18 R-Dynamic
Old Jun 23, 2024 | 05:45 PM
BKC JAG's Avatar
I got the same email, going to dealer tomorrow. Will pass on any info I get.
Old Jun 24, 2024 | 11:18 AM
BKC JAG's Avatar
Looks like it is just the valve replacement no software update, apparently some valves are sticking. No charge
Old Jun 24, 2024 | 12:00 PM
cpq100's Avatar
Did you have the work done? Did you notice any changes to the car after the change was made?
Old Jun 26, 2024 | 02:45 PM
Simonusa0's Avatar
Default H422v2 campaign
This is merely a software update. Not a purge valve replacement. See attached full description in photo. I had it done on my F-Pace…. Not going to let them anywhere near the software on my F-Type. Highly unlikely this would be a problem anyway.
Old Jun 26, 2024 | 04:46 PM
2020 R Dynamic's Avatar
I just had the service done and I did not notice any difference. I let them do it as my car is under the factory warranty until October and then another year under certified preowned. But again, I did not notice any difference. If I was not under warranty, I would not have allowed them to do it.
Old Jun 26, 2024 | 11:22 PM
Pie944's Avatar
R MY19, did it today and no difference. Just a software update.
Old Jun 28, 2024 | 08:49 AM
Simonusa0's Avatar
Update - I had the service completed with no issues.
Old Jul 2, 2024 | 12:48 PM
cpq100's Avatar
I had this update performed on my 2018 today. I did not notice any changes.
It took the technician four tries to do the update. After the first three failed he switched to a new diagnostic machine and it completed successfully.
Before I stopped at the dealer I checked both the Jaguar USA site and Topix to see if there were any other recalls listed for my car. Curiously there were no recalls listed not even this one H422.
Old Apr 25, 2025 | 07:25 PM
ihorbond's Avatar
Dealer performed this on my 2017 F Type S today and I already regret it. I feel like the idle is rougher now, I can feel vibrations in driver's seat, this wasn't the case before. RPMs are stable, not jumping and error codes but I dont like this new idle!!!! I'm pissed!
Old Mar 17, 2026 | 07:24 AM
superwofy95's Avatar
Before I stopped at the dealer I checked both the Jaguar USA site and Topix here if there were any other recalls listed for my car. Curiously there were no recalls listed not even this one H422.
This system stores fuel vapors from the fuel tank in a charcoal canister and later purges them into the engine to be burned during normal combustion. When an H422 fuel vapor purge fault appears, it may indicate problems such as a malfunctioning purge valve, clogged hoses, damaged vacuum lines, or an issue with the charcoal canister.
ferranpastor
E-Pace
Apr 29, 2024 07:45 AM
rorainey
Jan 5, 2022 05:27 PM
CJSJAG
Oct 18, 2021 08:22 PM
JaguarXKR
May 30, 2020 08:49 AM
carelm
Feb 8, 2009 02:52 AM
