How to clean the radiator above the splitter
Old Nov 18, 2021 | 03:27 PM
McPhaul's Avatar
Default How to clean the radiator above the splitter
So I posted about my trip to the mountains. https://www.jaguarforums.com/forum/f...dragon-253533/
Cleaning the car I found Lots of leaves lower radiator. Is that an oil cooler or a transmission cooler?
Anyhow, how do you clean this? It appears to close in on itself leaving no way for debris to get out. Do you have to just break ot the vacuum cleaner?
The first 2 pics are for location and the 3rd is all the crap I pulled out of it.
Thanks for the help
Old Nov 18, 2021 | 04:48 PM
Mbourne's Avatar
I guess a vacuum with narrow tube attachment is best. Otherwise your disassembling a million screws for the splitter under tray and cowl.
Old Nov 18, 2021 | 05:01 PM
DJS's Avatar
DJS
Now I wish I hadn’t looked at mine. I’ll pick out the whole oak leaves, and see how the compressor works for the rest. Hope there aren’t trees growing in there!
Old Nov 18, 2021 | 05:54 PM
Fireze22's Avatar
Try compressed air if you have it available.
Old Nov 18, 2021 | 07:03 PM
McPhaul's Avatar
I'm afraid that would force more particals into the radiator.
Old Nov 18, 2021 | 07:14 PM
Fireze22's Avatar
Blow it out from behind, maybe?
Old Nov 18, 2021 | 07:28 PM
Therock88's Avatar
Best, safest, and most correct approach (and time consuming) is to remove the front bumper/facia, and you will have full access to clean it properly. Otherwise, you can likely get the larger stuff out with a narrow vacuum device.
Bumper removal is about a 20-30 minute task...Not that bad really. I think there are lots of good tips on removal on the Project 7 Grille Threads that I and others posted in.
Good luck...
DC
Old Nov 18, 2021 | 10:14 PM
McPhaul's Avatar
Good luck...
DC
PaulsXK8
Oct 16, 2016 01:48 PM
scottmg
Jul 16, 2014 05:20 AM
brndst
Feb 24, 2014 02:52 AM
randyb
May 29, 2013 03:20 PM
AlfaVeloce
Apr 15, 2013 02:00 AM
