Injector replacement from the dealer
Old May 30, 2025 | 07:03 PM
Charlesr511's Avatar
Exclamation Injector replacement from the dealer
Hi All,
Can those who had their injectors for a v6 replaced by a dealer please let me know what you paid for this service and how many hours they used to do the install. My dealer is quoting 11 hours labor + parts for about $5K which seems way too much. How hard is this job that it takes so long?
Thanks,
Chas
Old May 30, 2025 | 09:06 PM
dennis black's Avatar
what's the reason for replacing your injectors
Old May 30, 2025 | 10:50 PM
Misfire on cylinder 4 & 5 so I just thought I'd do all six while its open
Chas
Old May 30, 2025 | 11:39 PM
Evoex's Avatar
Assuming you`re in the U.S. for about the same money in Canadian monopoly dollars i got;
-SC oil replaced
-SC Snout replaced
-SC Belt replaced
-SC Coupler replaced
-Accessory Belt replaced
-Upgrade cooling pipes to aluminum (aftermarket & OEM)
-Valves Cleaned
-Plugs changed
-Injectors inspected
This was at an indy British mechanic
Old May 31, 2025 | 05:03 AM
bjg625's Avatar
I bought my injectors, OEM, on Rock Auto along with plugs. One side and then the other 8 months later. Changed all plugs second time also. Used my inde and his labor was 1300 and 1400, total about 3300. He lets me acquire parts. This should have been a recall since It was corrected midway thru '15 model year.
Old Jun 1, 2025 | 09:55 AM
Pupilbone's Avatar
-SC oil replaced
-SC Snout replaced
-SC Belt replaced
-Valves Cleaned
-Plugs changed
Evoex - Would you mind passing on which Indy British Mechanic you use? I’m not sure on who to use after my warranty runs out. Thx.
Old Jun 1, 2025 | 09:59 AM
Evoex's Avatar
ofc
British Cars Service & Repair | Birkshire Automobiles
Old Jun 1, 2025 | 10:35 AM
Pupilbone's Avatar
Thanks, much appreciated.
Old Jun 1, 2025 | 12:31 PM
Evoex's Avatar
Ask for Jose, tell him Chris with the Ftype referred you.
Old Jun 1, 2025 | 08:49 PM
Do you show a code for what injector it is other than the missfire like this
before you start spending money
rosanova
Aug 8, 2016 02:24 PM
Only_one
Jan 6, 2015 03:43 PM
kbeachy
May 31, 2014 08:06 PM
mystype04
Jul 12, 2013 03:08 PM
jaginblack
Aug 5, 2010 11:12 AM
