Loose wire under front passenger wheel
Old May 23, 2020 | 10:13 PM
RayJag1's Avatar
Default Loose wire behind front passenger wheel
Took delivery of my dream (and first) car a few days ago. During some semi-spirited driving last night, my dash lit up with several messages: Emergency brake assist not available, Adaptive dynamics fault, ABS fault, Parking brake fault, Stability control not available drive with care, E-Diff not available.
Gave it a wash today and noticed a wire hanging behind the front right wheel. Pictures are attached.
My local service shop won’t be able to see me for another two weeks, so I’m wondering if anyone knows if this is something I can easily get fixed myself.
Thanks!
’16 F-Type R
Old May 24, 2020 | 03:17 AM
peppersam740's Avatar
OH MY;;; Could it be the brake pad sensor ?
Old May 24, 2020 | 03:27 AM
OzXFR's Avatar
Nup, no chance, that is always on the LHS not the RHS. For the front that is, opposite on the rear.
Looks more like an ABS wire to me.
Old May 24, 2020 | 03:36 AM
RayJag1's Avatar
Will jack the car up later today and post better pictures.
Old May 24, 2020 | 04:56 AM
Your right again. I didn't read the codes.
Old May 24, 2020 | 07:48 AM
Phil Edwards's Avatar
As you say Looks like the Wheel speed sensor Wheel speed sensor
Old May 24, 2020 | 12:55 PM
scm's Avatar
scm
Regarding all the faults, the first thing I'd do is give the battery a good charge, it's likely that it wasn't fully charged before you took delivery and low battery voltage can give rise to all sorts of weird faults.
Old May 24, 2020 | 04:39 PM
Unhingd's Avatar
The hanging wire is far more suspect. I’m betting that reconnecting the wheel speed sensor will resolve the warning messages.
Old May 24, 2020 | 04:43 PM
I would suggest from the photo it been damaged and will need replacing, you can see the white and black internal cores
Old May 24, 2020 | 04:47 PM
scm's Avatar
scm
Yeah, I realised that when I reread the OP. Properly!
Old May 24, 2020 | 04:52 PM
Unhingd's Avatar
You are correct. The connector is missing.
Old May 25, 2020 | 09:15 AM
Thanks!
’16 F-Type R
RayJag1 did you manage to get the wheel off and have look ? Part numbers are in my first post. Cost are uk pounds + tax.just gives you an idea of cost.
Phil
Old May 26, 2020 | 04:39 PM
Had a look at the speed sensor cable on my car as I had the front wheels off and looking how low the cable is hanging down in the photo, also the rubber gland on the end of the cable, it must have been ripped out of the plug behind the wheel liner.
Hope you get it sorted.
Phil
Old May 26, 2020 | 08:06 PM
Unhingd's Avatar
The cable probably snagged on something. Were you driving off-road?
Old Jun 5, 2020 | 01:30 PM
RayJag1 did you get things sorted out ?
Old Jun 5, 2020 | 01:59 PM
You know how they are. Once they get it sorted out they forget about us still waiting.
Old Jun 5, 2020 | 02:04 PM
as they it's good to share
shanonmatheson
Sep 1, 2022 09:09 AM
streamsaver
Jan 11, 2019 02:15 AM
Fraser Mitchell
May 13, 2018 05:17 AM
Cleanability
Feb 23, 2013 08:06 PM
afonda
Jan 27, 2013 04:13 PM
