Mobil 1...
Old Jul 24, 2019 | 03:56 PM
NavyBlue's Avatar
Default Mobil 1...
I know that that Jaguar recommends Castrol synthetic oil, & I have 2 Five quart jugs on the shelf.
But last oil change at the dealer, they used Pennzoil Platinum synthetic.
I've been using Mobil 1 synthetic for our family's 20+ cars over the past 20+ yrs with no issues.
With Walmart's sale of 5 qt jugs at $20 (now $22.88),
https://www.walmart.com/col/19-98-Cy...ype=10&veh=aff
I bought 4 for $80, did the online $12 rebate (x4 for $48 back) for my wife & kids' cars
https://apfco.com/secured/R10130W/
For future reference, after the 5 free/included oil changes from the dealer, I would assume I would able to use Mobil 1 instead of Castrol with no issues?
Anyone knows the max shelf life of synthetic oil?
Thanks,
Old Jul 24, 2019 | 05:43 PM
Unhingd's Avatar
Thanks,
As long as the container remains sealed, I can’t imagine that there would be a maximum shelf life.
Old Jul 25, 2019 | 06:14 AM
Nati's Avatar
Thanks,
Neither the pennzoil nor Mobil 1 carry the stjlr.51.5122 specification. I really don't understand why your dealer would use pennzoil. I'd be having a conversation with the service manager and JNA.
Old Jul 25, 2019 | 09:23 AM
Nedoerr's Avatar
This also recently happened on the XJ forum and lots of debate ensued. Find the thread here:
https://www.jaguarforums.com/forum/x...il-car-214892/
Old Jul 25, 2019 | 09:45 AM
Martyb's Avatar
Local dealer here in AZ also uses Pennzoil. I bought the correct spec JLM oil from them so they have it available, but still use Pennzoil when performing customer oil changes.
Old Jul 25, 2019 | 10:12 AM
Unhingd's Avatar
Jaguar engineers seem to place a lot of importance on high titanium content. That doesn’t seem to be a emphasis of the Pennzoil Platinum formulation.
Old Jul 25, 2019 | 10:39 AM
Itismejoshy's Avatar
do you have a theory as to why this is? Figured your the guy to ask.
Old Jul 25, 2019 | 10:44 AM
Nati's Avatar
As long as my car is under warranty not a drop of alternative oil is going in that engine. JLR will absolutely make you buy an engine if something goes wrong. At least in the OP's case he can hold it over the dealership, but they will try to cover their bottom line and make up a story for why they won't pay for it either.
Old Jul 25, 2019 | 10:52 AM
SinF's Avatar
Current best guess is to reduce negative effects of DI - chain wear and sludge on intake valves.
Also, I too was Mobil 1 fan until I noticed that my Subaru burned more oil when using Mobil 1. What was negligible oil burn otherwise ended up substantial when using Mobile 1 Fully Synthetic.
From Bob the Oil Guy:
Titanium
Titanium is a newer, more environmentally friendly anti-wear additive being implemented due to more stringent emissions regulations, and is phasing out the older, more harmful phosphorous compounds such as ZDDP (Zinc dialkyldithiophosphate). ZDDP reduces the effectiveness of the catalysts in catalytic converters by creating a plating effect when combusted, and covering the catalyst while Titanium does not. Titanium chemically binds to wear surfaces creating a hard, Titanium based oxide layer which reduces friction, thereby reducing wear. Concentration levels vary greatly depending on oil brand.
Old Jul 25, 2019 | 10:53 AM
NavyBlue's Avatar
Me thinks all these Titanium, Platinum, Gold, Silver, etc... are just marketing hype.
I'm sure that dealers wouldn't be using Pennzoil for our first 5 yrs free/included maintenance if it'll void the factory's 5 yr warranty.
Our previous Mercedes & BMWs has gone over 20 yrs without any engine issues on annual Mobil 1 synthetic changes, other issues (transmission, wear & tear, etc...) crops up first before the engine...
Old Jul 25, 2019 | 12:45 PM
SinF's Avatar
This isn't your 20 year old+ BMW, F-type has direct injection, variable timing controlled by oil pressure, runs thin oil that would ruin any 20+ year old engine... Disregarding oil spec recommendations out of misplaced oil brand loyalty is going to cost you (or next owner) dearly.
Old Jul 25, 2019 | 02:11 PM
Unhingd's Avatar
Thanks for the Bob quote. That explains it.
Old Jul 25, 2019 | 03:49 PM
Mulmur's Avatar
Jaguar dealer advised me awhile ago that the oil I use, Amsoil 0-30 is just fine and no warranty issues. They sell a lot of cars and have had bad engines go boom on occasion, using other than Castrol, and the oil was not an issue. Only point was to keep receipts to prove on time oil change, and/or have the dealer do them.
And yes, I know, its not 0-20, which is too thin for my liking so I go with 0-30 and have for over 10 years. Likely the 0-20 oil became popular due to gas mileage requirements.
My three jaguar v-8s all run great right up to red line.. etc...
Anyway lots of wear test info available that indicates Pennzoil is excellent as well, apparently full synthetic from 100% synthetic stock is considered top tear and if you believe the wear tests on the internet, Mobil may be a step down, but likely all good.
Gets down to personal preference and personal responsibility, while checking in with dealer just to make sure...
Lots of old threads on the 'oil debate' issue.
Lawrence
stremsjg
Mar 13, 2020 11:59 AM
Stu 1986
Oct 4, 2010 04:45 PM
matl
Feb 10, 2010 09:35 PM
cincinnati
General Tech Help
Jan 31, 2009 08:51 PM
