Oxygen Sensor Help!!!
Old Mar 12, 2024 | 10:19 AM
BigJay13's Avatar
Default Oxygen Sensor Help!!!
I'm having a rough day understanding the Bosch O2 Sensor part numbers to determine which sensors I need? I just can't figure them out for some reason. The codes are telling me that I need a Bank 1, Sensor 3 and a Bank 2, Sensor 3. Can someone please look at the Bosch part numbers and tell me which sensor I need. The car information is as follows: 2017 F-Type SVR 5.0L Supercharged V8
Thank you all in advance. I don't know what is wrong with me today.
Old Mar 12, 2024 | 10:27 AM
NBCat's Avatar
Check your VIN with a local Jaguar main dealer.
Depending on your location, JLR are covering the oxygen sensors for 2017 X152s for 10 years, or 120,000 miles whichever occurs first in the United States.
Old Mar 12, 2024 | 10:31 AM
alchemystic's Avatar
On your vehicle the O2 sensors are covered by warranty for 10 years or 120,000 miles.
For those with the V6, it's 15 years/150,000 miles
Old Mar 12, 2024 | 10:35 AM
BigJay13's Avatar
NBCat,
Thank you for the reply. My nearest Jag dealer is 2 hours away and they have told me they can fit it in April. I'd just rather get it done since it only takes about 2 hours to do. I'm just having a problem figuring out the part numbers.
Old Mar 12, 2024 | 03:46 PM
mattison's Avatar
Is that warranty to the original owner?
Old Mar 12, 2024 | 04:56 PM
scm's Avatar
scm
Should be for the car.
Old Mar 12, 2024 | 06:34 PM
OzXFR's Avatar
Bank 1 is the right hand side of the engine (looking forward from the front seat, or the left hand side looking at the engine from the front of the car), and the O2 sensors are three each side (pre-cat then mid-cat then post cat) and are numbered front to back.
So the two O2 sensors you are after are both of the post-cat ones i.e. the two rearmost in the exhaust system.
I *think* they are the same part with therefore the same part number but don't quote me on that as maybe they have different length wires.
Old Mar 12, 2024 | 06:35 PM
uncheel's Avatar
Correct. All of JLR's coverage goes with the car, including the initial 5-year maintenance.
Old Mar 12, 2024 | 07:07 PM
BritCars's Avatar
Yes. It's with the car. I had one of the sensor 3s (can't remember which bank) give an error code on my 2017 SVR and had the dealer do it on their O2 sensor extended replacement warranty
Was glad dealer did it in the end as it was apparently corroded into place and they had to drop part of the exhaust, extract, rebore the hole and replace. Took them quite a while even with the right tools
So - if I were you I'd just have dealer do it
If you diy then pls let us know how it goes
Old Mar 12, 2024 | 09:47 PM
Rondog's Avatar
To answer your question as to what the Bosch part number is: I found this at Parts Geek. Maybe it will help you. https://www.partsgeek.com/wfmfsr7-ja...0aAkSEEALw_wcB
Old Mar 13, 2024 | 07:39 PM
Valerie Stabenow's Avatar
150,000 for the v6 cars? Making note of that, thank you!
Old Mar 13, 2024 | 07:48 PM
Yes, for the 2014 to 2017 V6 F-type the O2 sensors are covered for 15 years or 150,000 miles.
Old Mar 13, 2024 | 08:44 PM
DNAer's Avatar
I replaced a bank 1 sensor 3 a week ago. I think it took me more time to put the car up on the lift than to replace the sensor. My car has never seen rain or snow so I can’t vouch for how easily your sensor will come out but it is a simple job barring that.
Old Mar 14, 2024 | 10:07 AM
Are the codes for failing/failed O2 sensors accurate for diagnosis/replacement purposes? Would there be physical symptoms of a failed sensor? I will be taking the F in for tire swap and can ask to have the OBD checked.
Old Mar 14, 2024 | 11:22 AM
DNAer's Avatar
No symptoms for mine. A fault light illuminated on the dash, I plugged in my reader and ordered the part…wish everything in life were that simple
Old Mar 18, 2024 | 06:10 AM
GeDaJew's Avatar
No. I had mine done last week (2017 F-TYPE S) I am not the original owner.
BritCars
Aug 23, 2025 02:58 PM
cdma
Mar 1, 2024 07:53 AM
MISH BA
Jan 26, 2022 11:58 AM
RGPV6S
Jan 26, 2021 12:19 PM
Traveller
Feb 27, 2020 10:13 PM
