P 7 Bumper-less Grille Installed
Old Jul 28, 2024 | 09:20 AM
  #581
MCMike37's Avatar
Talk about perfect timing, I'm in the process of making an E-Pace grille fit the car. Bought the E-Bay carbon fiber surround and will be in my second day of cutting and modifying the grille to fit well. Biggest issue is that the E-Pace grill has a spot for a 100mm emblem vice the standard 86mm and I just had to order one form the Netherlands as they are extremely hard to source.
Old Jul 28, 2024 | 11:06 AM
  #582
MCMike37's Avatar
And just finished up, it's not perfect, one of the holes in the side was stripped out so it's not perfectly flush, but from anything more than about three feet away you won't see it unless you know what you are looking for.
Not the final emblem, this is a very Jerry rigged one until the real one arrives from overseas ...
Old Jul 28, 2024 | 03:55 PM
  #583
Tork Monster's Avatar
I recalled posting questions on this thread, but I see I never posted the results of my grill project. I decided to buy a cheap grill off eBay, just to use the surround frame. It came in fake carbon fiber, so I painted it Santorini Black to match the car.
Replaced the grill, the four side grills, and the two hood vents with stainless steel mesh.
I used rubber grommets to mount the parking sensors, which worked great, but I still haven't reset the sensors yet.
This was a lot of work, but I am very pleased with the result.
A big THANK YOU to everyone who posted in this forum. Your input made it much easier to do this modification.
Here is a link to the quick vid I made on removing the nose to do this work:
Old Jul 29, 2024 | 09:09 AM
  #584
linuswue's Avatar
Maybe a stupid question, but does anyone know if the radiator grille fits the models from 2020 onwards?
The part number is MX5317F791A
Old Jul 29, 2024 | 09:21 AM
  #585
linuswue's Avatar
Sorry T2R42273 ist the part Nr.
Old Jul 29, 2024 | 10:31 AM
  #586
eeeeek's Avatar
If you're asking if the new grill will fit the 2020 and earlier car, no, it will not.
Old Jul 29, 2024 | 10:49 AM
  #587
Chuckster's Avatar
Tork Monster - I like the style of your wheels. What are they?
Old Jul 29, 2024 | 10:57 AM
  #588
Thank you!
​​​​​​​These are 21" VS-Forged VS-03.
Old Jul 29, 2024 | 11:07 AM
  #589
Chuckster's Avatar
Went to Vorsteiner site - Looks like they don't make that style anymore. Bummer.
Old Jul 29, 2024 | 11:27 AM
  #590
eeeeek's Avatar
https://youtu.be/iMQoM8ANxvI?si=EblYsPO3TW2duvPb
I like it. It reminds me of the old XJRs and XKRs. The reason it works is you changed ALL of the vents to the mesh, otherwise it just would have looked off. Nicely done.
Old Sep 4, 2024 | 07:43 PM
  #591
MCMike37's Avatar
Forgot to post the final results once I got the official E-Pace logo installed....
Old Sep 5, 2024 | 01:35 AM
  #592
Slappy's Avatar
Tork, looks great. Stainless / nickel look really works for me, and I hate the giant black plastic milk crate of the stock and even P7 grilles. Nickel side and hood vents might be nice too.
Anyone here try the Arden grill or something similar? Arden seems to be a very boutique German or Swiss outfit, not sure how easy to work with them from the US.
Old Sep 7, 2024 | 02:02 AM
  #593
linuswue's Avatar
@Slappy Thanks for the tip, I sent Arden an enquiry and received the following reply.
Dear Mr XXX,
Thank you for your enquiry. Unfortunately, we have removed the radiator grille from our range and are therefore unable to offer it to you.
Kind regards
Arden Technics
Old Mar 22, 2025 | 05:17 AM
  #594
J444G's Avatar
I have pulled the trigger and bought a VR v2 grille. I have two questions
1) I have a styrofoam cover over my front crash bar - should I keep it, or remove it? My line of thought is that if I remove it the airflow would be quite different, since it seems it blocks the whole "top" area over the OEM crossbar.
2) parking sensor's cables are installed inwards. I red that I have to keep the angle of sensors exactly like OEM to them work correctly, but I also red that someone turned them 180 degrees so the cables are pointing outward. Can I do that?
Old Apr 7, 2025 | 10:47 AM
  #595
J444G's Avatar
There are 2 unknown sensors attached on the original grille, looks like g-sensors for airbags? Do anybody know what they are and are they any rules how to install them back? Thank you
Old Apr 7, 2025 | 11:43 AM
  #596
bfrank1972's Avatar
Those are parking sensors - some of the aftermarket grills have mounting points for them, and for others you have to fabricate something. You need to get them to the right height and make sure the grille isn't interfering, or they won't work correctly. Also I think folks get rid of the styrofoam, and paint the metal bar black (if it's not already black). I haven't done this mod myself, just what I've read about it.
Old Apr 8, 2025 | 01:54 AM
  #597
J444G's Avatar
Sorry but they are not There are other sensors hidden on the top of the grille..
Anyway I have found it and they are Pedestrian Impact Sensors
Old Apr 8, 2025 | 05:43 AM
  #598
bfrank1972's Avatar
Lol sorry about that - are those to let us know we have run over a pedestrian? (J/k )
Old Apr 8, 2025 | 06:46 AM
  #599
OzXFR's Avatar
All joking aside, those sensors when triggered fire off the pedestrian airbags under the rear corners of the hood/bonnet, blowing the bejesus out of it and costing you squillions in repair costs.
Never read or heard of a single pedestrian being "saved" by this dopey system and there are hundreds of reports of false deployments across a whole range of Jags including XF, XJ and XK, costing the poor unfortunate owners big time.
However very few reports of it firing on an F-Type so it seems JLR in their wisdom adjusted the sensitivity for the F-Type.
xdave
Jan 23, 2024 06:16 PM
powerhouse
Dec 2, 2022 09:47 PM
TheGuvnr
Feb 1, 2020 07:09 AM
Thermo
Oct 16, 2018 01:32 PM
MT500
Mar 2, 2015 04:03 PM
