P300 one year later, second topspeed attempt.
Old Aug 24, 2019 | 05:00 PM
Dan_NL's Avatar
Default P300 one year later, second topspeed attempt.
So I post again the first attempt we did.
..who beats our topspeed of 255kmh in a P300 .. ..where you legally can... :P
Last year, on a 'no limit' highway in Germany, we were 'ahead-of-the-game' after driving along roadworks respecting the 80kmh speedlimit.
Ofcourse you then upset people behind you, but we did have a complete empty road ahead for about 5 kms...
Just run-in, about 3100 km . Rev limiter cuts in at 249kmh :
Again, a year later, more then 16.500 km covered, so well run in.. .. no rev limiter !
Old Aug 24, 2019 | 06:44 PM
BruceTheQuail's Avatar
Looks as though it is sitting nicely on the road even at that speed. How did it feel?
Old Aug 24, 2019 | 08:08 PM
Unhingd's Avatar
https://youtu.be/FUuI6idgtZo
https://youtu.be/b6Ts2tsFBVA
Not bad for a 2.0l 4-banger pushing close to 2 short tons.
Old Aug 25, 2019 | 02:06 AM
Dan_NL's Avatar
Well, I had a Renault Supercing 1.4 GT Turbo in 1987. A 3 door hatchback with just 120Hp, frontwheel drive..
It did 205kmh on a straight, after a while.. ..in 1987..
It was less heavy [ around 1200Kg me included ], but still. Thirty years on and 300pk ; why not 250..
We were amazed ti continued pulling at 255 . Some day we'll test how fast it really goes, after a while.
We did sense every 10kmh more beyond 230 was squezing it..
Old Aug 25, 2019 | 05:44 AM
xrix4096's Avatar
I hate to be that guy but weight has no real bearing on top speed, just affects how long it takes to get there...
Old Aug 25, 2019 | 11:22 AM
Unhingd's Avatar
true, but it just sounded better throwing some weight around. lol
Old Aug 25, 2019 | 11:44 AM
Nedoerr's Avatar
I would imagine rolling resistance being weight dependent which could change top speed. Perhaps not a huge impact though.
Old Aug 25, 2019 | 12:15 PM
Unhingd's Avatar
Rolling resistance through the wheel bearings would result in no more than 4 lbs of resistive force on a 4000 lb car. Rolling resistance for tires will average about 1lb for every 100 lbs of weight on a smooth surface depending on tire inflation, but could be significantly more on a rough surface at speed. So yes, available hp for speed is definitely impacted by vehicle weight but how significant compared to aerodynamic drag is something for which I’m too lazy to calculate right now. Besides, I can’t seem to find the coefficient of drag for the F-Type.
Old Aug 25, 2019 | 01:46 PM
Dan_NL's Avatar
The drag is quite unpredictable. There was a TV show once about KAHN, he wanted a certain model of spoiler but had no budget to test it.
So they build it anyway. Result was that the front wheels came off the ground at higher speed.. ..it didn't stay on long...
Anyway, I did raise tire pressure from the adviced 2.5 all 4's to 3.0 all 4's . Noticed my tires were wearing on the outsides mostly,
didn't do that many doughnuts..
Old Aug 25, 2019 | 04:47 PM
Unhingd's Avatar
44psi will certainly help to reduce the rolling resistance from the tire.
Old Aug 27, 2019 | 01:26 PM
powerhouse's Avatar
Have mine just over 16 months now and the engine is well run in now, seems to have got more responsive, drove a 2019 model and seems sluggish in comparison, looks like this engine gets better with age.
The 2.0 turbo has plenty of power increasing options, see this article.
A 2.0-litre turbo four, paired with a six-speed sequential transmission, and producing 521 hp and 372 lb-ft of torque, enabling the Chinese concept to hit 0-62 mph in 4.4 seconds and a top speed of 193 mph.
https://carbuzz.com/news/jaguar-xe-s...mK97og3C4sxbBA
Old Aug 27, 2019 | 01:29 PM
xrix4096's Avatar
Yeah, why not 100psi or just install some metal hoops instead of rubber? ;-)
Old Aug 27, 2019 | 01:33 PM
Dan_NL's Avatar
Well, effectively that's what happens when you increase the wheel size on a car : the tires become a smaller part of the "hoop" ,
and you end up with a rock hard suspension....
Old Aug 28, 2019 | 09:45 AM
StormtrooperFtype's Avatar
Fastest my V6 S able to hit with the top up was 170, and after 160 it took a long long time to get there. It may have a little bit more left in in, but not much, Also not too many place you can do that safely, and even so the thought of passing a cop is pretty scary. Anyone else get anything better with their V6? top down It didn't get past 164 but it did not feel stable after 155.
Old Aug 28, 2019 | 06:26 PM
Unhingd's Avatar
I believe the stock S Tune is electronically limited to 171mph (275 km/h)
Old Aug 28, 2019 | 06:48 PM
xrix4096's Avatar
Are the gear ratios the same (obviously only for the slushbox) on the v6 and v8? The final drive? I understand the diff is different but can’t see any info about ratios
Old Aug 28, 2019 | 07:24 PM
Unhingd's Avatar
The I4, V6, V6S and V8 all have different final drive ratios (3.55, 3.15, 3.31, & 2.56 respectively). The AT and MT have different top gear ratios as well.
DJS
Nov 24, 2017 05:49 AM
Lookout!
Dec 17, 2015 09:57 PM
powerhouse
Sep 20, 2014 05:06 AM
Autobahn kid
Oct 19, 2013 01:10 PM
