Patched tire safety...
Old Sep 3, 2019 | 03:19 PM
NavyBlue's Avatar
Default Patched tire safety...
Just came back from 2nd trip to Discount Tire, which did an outstanding job of removing my 2nd nail & patched up my rear right tire. Luckily it was in the repairable area.
So is there a max # of patched repairs per tire before it's unsafe...?
Thanks,
Old Sep 3, 2019 | 04:19 PM
Mahjik's Avatar
In theory, it really depends on how close the patches are to one another. The more patches near each other the less rigid the tire will be.
Old Sep 3, 2019 | 06:05 PM
jaguny's Avatar
How far did you drive with the nail? Did your tpms sensors register a pressure loss? Do you recall what pressure it leveled at? I had a screw in rear tire this summer and dropped to 27 lbs.from 37 and then seemed to stop losing air. Drove about 1/4 mile on it.
Old Sep 3, 2019 | 07:49 PM
NavyBlue's Avatar
It dropped from 37 psi to 29 in 2 weeks, after I got back from vacation. Pumped it up to 38 to limp to Discount Tire, Nail was about 5 o'clock to the 1st patch job at 12 o'clock, so almost opposite side, luckily both were right in the middle of the tread, so I guess Discount Tire thought it was OK to patch again.
Old Sep 5, 2019 | 09:08 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Numbers of patches are irrelevant. It matters where the repair was, tread or sidewall, how close together, I wouldn't want patches over lapping, how large or jagged the hole was, and if the steel belts were exposed to water. Most times I would run a patched tire as I would any other. Now obviously I wouldn't try to drive a race car on a patched tire but normal highway speed limits, a repaired tire, even several patches should be fine. When you have to make a judgement call, I usually go on the safety side, if the wife and kids are riding in it. Just my thoughts. Don't be stupid.
Jack
Old Sep 6, 2019 | 10:56 AM
Nedoerr's Avatar
I currently have two patches on one of my my rear tires (non-sidewall). Heavier XJ that is driven spiritedly. No problems.
All the best.
Old Sep 8, 2019 | 06:25 AM
Paul_59's Avatar
Banned
If I had a car with 'ordinary ' levels if performance I might consider tyre repairs.
Whenever I have owned high performance cars I would never consider tyre repair as I tend to use the performance
Some people will consider this extravagance but I prefer complete peace of mind with tyres, brakes, suspension etc.
I have replaced a nearly new PS4S with a few hundred miles on it when I got a nail
Old Sep 8, 2019 | 10:37 PM
MisplacedPriorities's Avatar
Obviously if you do burnout like I eat lunch every day, you'd want to replace the entire tire. Barring that, it's irrelevant how many patches you have, only the quality of the patch that matters.
Old Sep 10, 2019 | 04:22 PM
Paul_59's Avatar
Banned
I don't do burnout, but I do travel at very high speeds where it's legal, let's just say significantly in excess of 150mph.
I don't want a patched tyre failing due to stress and temperature from high speed use and know of no way to accurately determine the "quality of the patch" and would doubt that any tyre repair would be warranted to the same load and speed rating as an original tyre.
Your money and your choice
Old Sep 10, 2019 | 10:03 PM
RacerX's Avatar
Banned
I patch my tires with a kit on the spot if the hole is through the belts. It takes less than a minute to rasp and punch in a plug. The hole needs to be rasped to a small clean circle to promote a good seal, after that the only quality aspect is if it holds air or doesn't. The patch isn't going to add structural integrity.
Old Sep 11, 2019 | 05:22 AM
Nati's Avatar
That would be a plug not a patch, then, yes?
Pirelli specifically does not endorse repairs of any kind. I believe they say the speed rating is void on a repaired tire.
Old Sep 11, 2019 | 03:23 PM
David Meier's Avatar
I have two patched tires on my BMW 6 Series Gran Coupe and have had zero issues over the past year. It does, however, depend on where the puncture is and how it is repaired. In principle, there's nothing wrong with a patch.
BigCat09
Mar 11, 2025 06:06 AM
wcoy
Mar 5, 2018 09:28 PM
bobdr1
F-Pace (X761) / C-X17
Sep 13, 2016 05:54 AM
Donzi
Dec 20, 2015 08:48 PM
sandydlc
Apr 30, 2012 06:09 PM
