Revers Camera Problem
Old Sep 7, 2016 | 08:30 AM
jbajor's Avatar
Default Revers Camera Problem
Lately when I first start my car (2017 F-Type Convertible) in the morning I get a 'Camera System Fault' warning on my dash display. The reverse camera is inoperative either in reverse or when trying to manually turn it on from console. It seems to go away and become functional after driving for 20 minutes or so then is fine for the rest of the day. I have not yet contacted the dealer service. Has anyone experienced this and if so, what was found to be the problem?
Old Sep 7, 2016 | 10:05 AM
WhiteTardis's Avatar
Since the car actually displayed an error message, theres a good chance that its been logged and has been stored. Considering that its intermittent, i'd say that its a loose cable or ground somewhere. Dealer should be able to pull the error code diagnose pretty easily.
Old Sep 7, 2016 | 10:07 AM
jbajor's Avatar
Thanks! Just made an appt to take the cat to the vet...
Old Sep 14, 2016 | 08:56 AM
jbajor's Avatar
update... I took car into the dealer... fault cleared (as usual after ~30min of driving). Dealer could not duplicate fault and no error codes had been thrown. They kept car over night (inside). Next morning still no faults. Kept another night and this time duplicated my conditions... kept it outside (chilly) and started it early (6:30am) in the morning. Fault was confirmed upon start up!! Hurray! Now, what to do to fix it.... I'll keep you posted.
Old Sep 19, 2016 | 08:43 AM
jbajor's Avatar
Dealer inspected all cable connectors from camera to back of head unit... all good. Ended up replacing camera and, so far, all is good! I can't say enough good things about the team at BMC in San Francisco!
Old Apr 4, 2023 | 10:30 AM
MHSXE's Avatar
Default Fix Camera Solution
Hello friends, here I bring you the solution to the reverse camera failure in Jaguar, put subtitles 👍🏻 ➡️ 🎥
Old Apr 4, 2023 | 10:36 AM
MHSXE's Avatar
Old Apr 4, 2023 | 10:38 AM
MHSXE's Avatar
Default Solution fix camera
Old Apr 4, 2023 | 10:47 AM
sov211's Avatar
Lo dudo mucho....the fact that after 20 minutes of driving the camera in your car becomes operative strongly suggests that the battery is the problem - insufficient voltage until the car has been run long enough to add charge to the battery. Further, the camera on the F-Type is not mounted on the trunk lid (as it is on the XE in the video), so abrasion of the cable is very unlikely.
Is your battery fully charged?
Old Apr 4, 2023 | 12:20 PM
CJSJAG's Avatar
Probably a stupid question, but are you certain no condensation or water droplets obscured camera?
Only time my camera has done this it related to a wet or dirty lens.
Spanjab
XE ( X760 )
Oct 11, 2022 04:33 PM
Clutch
Apr 24, 2022 09:23 AM
Kamran Soleimany Far
XF (X260)
Feb 19, 2020 03:12 AM
thebigcat
Jan 20, 2020 02:51 PM
Tim Lee
Nov 17, 2017 10:03 AM
