Rust
Old Jun 13, 2017 | 04:32 AM
jonbon's Avatar
Default Rust
I do have after the first year quite some rust on the exhaust and other parts underneath the car ... Is this normal? I drive in Switzerland and they told me that this was a car which was imported from Gibraltar and therefore it has another "conservation" .. can this really be true?
Old Jun 13, 2017 | 04:57 AM
Unhingd's Avatar
Pictures, please. Hard to believe since everything under there is either stainless steel or aluminum. I could understand if the fasteners are rusting.
Old Jun 13, 2017 | 05:36 AM
Originally Posted by jonbon
..... they told me that this was a car which was imported from Gibraltar and therefore it has another "conservation" .. can this really be true?
Welcome to the forum jonbon,
Over the years Jaguar have consistently managed to find a grade of stainless steel for their exhaust systems which rusts in the northern European climate! However, I'm surprised a recent ex-Gibraltar vehicle would be affected.
The Jaguar Land Rover distributor in Gibraltar is A M Capurro at 20 Line Wall Rd, Gibraltar GX11 1AA (tel +350 200 75149). I keep their details in my phone as I drive down to Gibraltar most years. A call to ask what they know of your vehicle may provide some useful information on its history.
Old Jun 13, 2017 | 08:06 AM
f-driver's Avatar
unfortunatly all steel parts e.g. the subframes aren't protected sufficiently against rust .
https://www.ftypeforums.co.uk/viewto...07&hilit=rusty
Even on my car which has been driven only 3 times in rain during the last
4 years you can find some rust on these parts .
Definitely not build for winter use .
Regards
Ulrich
Old Jun 13, 2017 | 08:15 AM
SinF's Avatar
Would it be worthwhile to spray it with oil, or is it likely to create more issues?
Old Jun 13, 2017 | 12:26 PM
F-typical's Avatar
They spread rock salt on UK roads in winter to prevent ice build up. If there's any stainless steel and aluminium in direct contact, that would be bad...
Old Jun 13, 2017 | 02:57 PM
Unhingd's Avatar
Your properties of materials must be different on that side of the pond. Here, salt will not affect stainless, and the surface oxidation on the aluminum (maybe not on aluminium ) actually protects from further corrosion.
Old Jun 13, 2017 | 03:13 PM
DJS's Avatar
DJS
Think he's referring to the fact that if stainless and aluminum are in contact with each other, galvanic corrosion can occur. But presumably, that would simply be bad design.
https://www.fastenal.com/content/fed...0Corrosion.pdf
Old Jun 13, 2017 | 07:58 PM
Unhingd's Avatar
Yes...that be true. The stainless pipes are physically isolated from the body with rubber mounting blocks.
Old Jun 14, 2017 | 01:21 PM
F-typical's Avatar
He is. For a home science demonstration of this, put a stainless bolt and a cola can in the pan after you've Brined the Turkey and connect them with a voltmeter.
Or, if it's an "aluminium" pan you're using, just add the bolt.
Footnote: If you use your boat in anything other than freshwater, go and check that there are no instances of stainless steel/alloy contact...
Old Jun 28, 2017 | 10:51 PM
OpenF's Avatar
Its even worse with radiators or intercoolers that are piped to some other bit to result in mixed metals contact across a fluid medium. Ever seen a high-end custom computer where somebody used an aluminum radiator and a copper water block?
Old Jun 28, 2017 | 11:17 PM
zmoothg's Avatar
Is there anything that can applied to prevent this from happening?
Old Nov 1, 2020 | 07:28 PM
mlebofsky's Avatar
Good question. I'm getting ready to possibly take my SVR with me to live at the beach....
Old Nov 1, 2020 | 11:46 PM
lizzardo's Avatar
I don't think any beach within a couple of hours of Highlands Ranch, CO should cause trouble.
Old Nov 4, 2020 | 02:24 PM
adityab's Avatar
Check out the savage geese video below. They comment on the rust issue as well--and suggest it might be warrantied
zray
Sep 20, 2018 09:10 AM
PaulB
17
Jun 22, 2015 11:46 PM
Usmc_Kak
May 14, 2014 01:13 PM
XJRChad
Aug 14, 2013 08:48 AM
backin15
Jun 18, 2012 10:03 AM
