Servicing dealer has "no idea" of in-service date?
Old Sep 20, 2018 | 09:42 AM
  #41
Paul champagne's Avatar
When I check cold, I always get "unavailable"
Old Sep 20, 2018 | 09:51 AM
  #42
fujicoupe's Avatar
Banned
Have you tried without actually starting the car, just by pressing start with your foot off the brake? That works for me, as well as checking warm ten minutes after shutting down the engine.
Old Sep 20, 2018 | 10:03 AM
  #43
Yes, that is what I do. But if the car is cold, I only get "unavailable". Even if I tap "cancel" twice, I still only get unavailable.
If I go through the manual steps: warm the car, wait 10 minutes. Then I get the level.
Old Sep 20, 2018 | 11:06 AM
  #44
scm's Avatar
scm
Interesting. From cold I get "underfilled" because I'm parked on a slope - it reads "OK" when checked on level ground. My previous XKR said "unavailable" on the same slope.
Old Sep 20, 2018 | 11:19 AM
  #45
That is something that must have been fixed on later model years. I've tried all the above directions in different combinations and patterns, and alas, when cold, I only "unavailable"
I'm going to try again on the next full moon, that might make a difference
Old Sep 20, 2018 | 11:28 AM
  #46
fujicoupe's Avatar
Banned
"I'm going to try again on the next full moon, that might make a difference."
Only works if simultaneously swinging a paper bag with a dead black cat inside.
Old Sep 20, 2018 | 12:14 PM
  #47
Tried that, didn't work. Please don't tell my wife
Old Sep 20, 2018 | 01:45 PM
  #48
Carbuff2's Avatar
Paul,
The service manual says to select engine oil display. Then press the Cruise Control Cancel button twice within 2 seconds to display the live reading of the Engine Oil Level.
(Page 2410, steps 9 - 13)
See if that works for you.
Farther down, (step 15 - 18) the process for updating the AVERAGE oil level is described. Perhaps your car doesn't have enough 'history' to display that?
(I was just looking for the method of replacing/checking ATF when I ran across that) WHEW
Old Sep 20, 2018 | 02:23 PM
  #49
Originally Posted by Carbuff2
Paul,
Thanks. That is what I've been doing. Accessory only. Engine oil display. Cruise Control Cancel button = "unavailable"
Also tried with the hood open. Then tried with the door open. Then both hood and door. Always using the cancel button (twice within 2 sec.) Always get "unavailable" when cold.
The car has 30K miles, so I assume it has enough history. Unless they wiped it when they did the CPO.
Old Sep 20, 2018 | 02:26 PM
  #50
ndabunka's Avatar
That is normal.
1. The ONLY way to get a reading without running the car is to NOT start the car but rather to simply press the START button without your foot on the pedal. Then toggle through with your drivers side door CLOSED to see what your COLD oil level is.
2. If you start is and drive for a while, like 10-20 minutes you still cannot get a reading. You have to wait another 10 or 15 minutes AFTER you have turned the car off and go back and read it again. Yeah, pretty stupid method as few of us are going to remember, or want, to go back out in the garage 10 minutes after we get home. We are busy people with other priorities that to remember we have to go back out to the car to check the FREAKING oil levels! Shesh... LOL
3. Use the other method of releasing the front hood/bonnet, press start (with foot OFF brake so that the car does not actually start), toggle through to Oil Level & then hit Cancel TWICE. If you release the hood AFTER you press start it won't work. If the drivers side door is closed, it will say "un-available". You have to do all of #3 with the drivers side door OPEN
Old Sep 20, 2018 | 03:11 PM
  #51
Originally Posted by ndabunka
That is normal.
OK, I started over, following the steps you listed. Tried #1 (door closed) It worked
Tried #3 (open hood before pressing START), door OPEN, Cancel twice.: yes, it also worked
It should not be that difficult. But BIG Thank You for listing the steps so clearly
Old Sep 21, 2018 | 12:16 AM
  #52
ndabunka's Avatar
Glad to hear. Please click on the "THANKS!" button at the bottom of that post above if you don't mind. It will help others find it
Old Sep 21, 2018 | 06:23 AM
  #53
Carbuff2's Avatar
Difficult, you say? Thank goodness the procedure doesn't require rubbing your tummy while patting your head.
OR is it, patting your tummy while rubbing your head????
Old Sep 21, 2018 | 08:31 AM
  #54
ndabunka's Avatar
Wink
You gotta be careful these days as those actions could land you in jail as not everyone appreciates dexterity
OH! You meant YOUR OWN belly & head.
Would someone tells the Hooters girl I mis-understood the "Internet Challenge"...
is led away in handcuffs.....
by the Hooters girl for a more private session...
Old Sep 21, 2018 | 10:10 AM
  #55
OK, now that actually made me LOL
NavyBlue
Aug 2, 2018 09:54 PM
jaguny
Apr 11, 2013 08:26 AM
Car-Nut
Jun 12, 2011 07:45 AM
XK NYC
US Northeast
Feb 2, 2011 08:02 PM
