SO THIS just happened.
Old Oct 14, 2021 | 09:22 PM
Jonathan Ivgi's Avatar
Default SO THIS just happened.
Middle of driving. All
of a sudden car “feels” as if it’s in Neutral. Battery image appears and then the D both on the gear shift and on screen are Blinking. I hit the gas pedal RPMs go up car goes Nowhere. Parked turned the car off and on again. Worked! For about an hr. Repeated the process and so far it’s been ok. I have to note that I’m also experiencing a strange hesitation when putting the pedal down, like the car is struggling to accelerate.
anyhoo hope this helps, no check engine light whatsoever.
2015 Jaguar F-Type R. 50k mileage.
Old Oct 14, 2021 | 09:34 PM
2018XF25T's Avatar
What's the battery voltage? It could be the battery is on it's last breath & need a newer one.
Old Oct 14, 2021 | 10:34 PM
OzXFR's Avatar
Yep, the first thing to check is the battery. Hook it up to a charger/tender overnight and see what happens, if still no good time for a new one.
The second thing to do is chuck a code reader on it and see what codes come up.
Then go from there.
Old Oct 15, 2021 | 04:20 AM
scm's Avatar
scm
Could that just be the car taking a while to think about downshifting for better acceleration? That can sometimes take a couple of seconds?
When I experienced hesitancy on accelerating it was because the electrical connector on the fuel pump was loose and making intermittent contact. But I got low fuel rail pressure codes and other symptoms, too.
Old Oct 15, 2021 | 09:35 AM
Valerie Stabenow's Avatar
If your 2015 still has its original AGM (Absorbent Glass Mat) battery, it sounds like it is ready for replacement. You may want to research Li Ion batteries and see what you think.
https://antigravitybatteries.com/pro...es/automotive/
6 years is about all the AGMs are good for.
Old Oct 15, 2021 | 10:10 AM
This might be the case. Before all this I was getting a warning to turn on the car since batt was low
Old Oct 15, 2021 | 10:29 AM
zach05855's Avatar
I think you have a Battery problem. Easy and relatively cheap fix.
Old Oct 15, 2021 | 10:31 AM
scm's Avatar
scm
Yeah, that sounds the first thing to fix.
Old Oct 17, 2021 | 11:34 PM
I don’t know. It seems to happen when I accelerate quickly. Right passed the 5 rpm it starts to “jerk”. Does Not happen if I accelerate Gradually.
gonna definitely change the battery. Put in fuel injector cleaner. Maybe have the tech check solenoids? Definitely going to change transmission fluids
Wunderboy987
Jun 12, 2021 01:18 PM
Portlander
May 31, 2021 04:02 PM
Marv152x
Dec 17, 2020 11:32 PM
atl-ftype
Mar 20, 2018 01:04 PM
x42bnx
Dec 23, 2015 07:45 PM
