Sudden power loss. 2.0
Old Apr 22, 2020 | 03:56 PM
Tomkatb's Avatar
Default Sudden power loss. 2.0
F 'type 2.0
i was driving back from a grocery run this morning. Taking the long way home.
i slowed for guys working on the road. Then put the pedal all the way down in dynamic S. Car accelerated poorly. Hit ,6,000 rpm and badly stumbled.
Car would accelerate like it had 40% hp. Limp mode? Drove that way about 4 miles home. Planned to let it sit a bit and then call the dealer.
let the car set several hours. Went for a ride. Everything is perfect again.
Any clues? Car has 6,500 miles, 2018 2.0.
Old Apr 22, 2020 | 04:19 PM
RGPV6S's Avatar
Did you recently fill up with gas? Maybe water in the fuel or clogged fuel filter?
Do you have a OBD II code reader? If not go to car parts store see if it is throwing any codes.
Old Apr 22, 2020 | 04:28 PM
Tomkatb's Avatar
No fuel recently.
I am surprised if it did cause a code, there was no light on the jag dash.
Old Apr 22, 2020 | 04:50 PM
Phil Edwards's Avatar
I take it you didn't knock the Automatic speed limiter (ASL) by mistake ?
Phil
Old Apr 22, 2020 | 06:56 PM
lizzardo's Avatar
Full throttle overrides that, at least in my model year.
Old Apr 22, 2020 | 07:20 PM
Mahjik's Avatar
Not all codes will trigger a CEL. Some of them are just stored in the ECU.
Old Apr 22, 2020 | 07:30 PM
OzXFR's Avatar
Yep, it went into "restricted performance" (limp) mode but who knows why.
There should be at least one error code stored, get yourself a decent code reader (like an iCarsoft LR 2.0) and check for codes (then post them up here), then clear the codes, go for a run and check again to see if any codes came back up (unlikely).
A good code reader is a must-have on these cars and can (and usually will) save you many times it's cost in diagnosing problems, especially the simple things that a dealership will charge you squillions to diagnose.
Old Apr 23, 2020 | 03:32 PM
madmax1911's Avatar
simple things that a dealership will charge you squillions to diagnose.[/QUOTE]
Same pricing scheme in OZ as US 😂
Old Apr 23, 2020 | 04:45 PM
Tomkatb's Avatar
Today everything is peachy!
amazed how well the car behaves in wet weather. Our other vehicle is a diesel hd truck. Now that is a terror in wet weather.
I will need a scanner to see anything.
having come from a 63 MGB I really am not fond of all the new technology. KISS is my motto. Bought the simplest f type.
Old Apr 23, 2020 | 05:16 PM
RacerX's Avatar
Banned
F 'type 2.0
Sounds like a traction control hiccup.
Old Apr 23, 2020 | 11:39 PM
JacksonvilleJag's Avatar
Oz, I also got the iCarsoft LR 2.0 and like it for simplicity and functionality. I haven't had any issues with it at all. Have you had any of the OBD II issues after plugging it in?
Old Apr 24, 2020 | 12:07 AM
OzXFR's Avatar
I have never had a single OBD2 or battery issue and I plug in the LR 2.0 about once a month to check for codes.
Old Apr 24, 2020 | 03:38 AM
That's good to know. I've only used it a couple times for some O2 sensor codes and haven't had a battery drain issue yet.
Old Apr 24, 2020 | 07:18 AM
Tomkatb's Avatar
Is that battery drain issue real?
I would prefer not to disconnect the battery every time I used the scanner.
my car is under warranty for 2.5 more years.
Old Apr 24, 2020 | 07:40 AM
scm's Avatar
scm
If you've used the scanner without seeing the issue you should be safe - I believe the behavio(u)r is consistent.
Old Apr 24, 2020 | 07:41 AM
I haven't had any issues using the scanner, and as Oz said, he hasn't either. I only asked because there are other posts where plugging into the OBD II causes battery drain. Apparently this is not an issue with iCarsoft LR 2.0. Or at least in our two experiences.
Old Apr 24, 2020 | 08:04 AM
Tomkatb's Avatar
Where to purchase?
i saw this one on Amazon for 40% less than the manufacturer. Legit?
Old Apr 24, 2020 | 08:12 AM
Where to purchase?
I got mine off of Amazon.
Old Apr 24, 2020 | 08:22 AM
Tomkatb's Avatar
Geez. A lot of the reviews are, not good!
SunFlower
Sep 22, 2019 08:16 AM
harryxtype
Nov 13, 2017 09:48 AM
Philip71
Apr 30, 2017 02:38 AM
NoScurdyJags
Apr 3, 2017 06:43 PM
Mrjim
Sep 17, 2016 10:29 PM
