Track Day
Hey guys,
I just posted a youtube video of my first track day in my V6 S at the KMT in Kuwait.
Just wanted to know if you guys have any tips and tricks to improve my driving, and any post track day maintenance tips.
I live in the the States, but am often in Kuwait for business, and currently here for what will be a little while longer than expected. Been to KMT many times for different events and looking forward to it opening again. Always a good time.
My first recommendation is to mount your camera inside your cockpit. To be able to help (virtually) coach, your driver inputs also need to be in view. I'll post an example video below. With the F-Type, you'll probably need to suction it to the rear window and aim it forwards. Make sure to set "Spot Metering" on when setting it up to operate inside the cockpit. Example video (not from an F-Type:
Also, the wind noise is pretty substantial from that mounting position so it's hard to hear the engine. The few times I could hear it sounded like you were hunting for the right gear as you were coming out of a corner (i.e. you'd come out of a corner and then downshift to get more speed). You want to enter a corner with the gear you are expecting to use when you are going to (eventually) accelerate out of the corner..
https://youtu.be/jxwBDkakvQE
This original "Shoot" was taken on my way to work several years ago! I really wasn't in much of a hurry that Day and didn't know that it had gotten out on the Web....Wish now that I had really gotten on it! Oh Well! I hope you enjoyed it......
Billy Clyde @ Cinco Ranch
Looks like fun. My two cents.
1. Use ALL the track. Drive the car all the way to the outside edge at track out. The car will accelerate faster because you are using less steering lock after the apex. Eventually you'll reach the point where you are applying enough throttle coming out of the corner that you have to go all the way out, so get used to that line now. And don't creep in before turning in. You should be right at the outside track edge when you being your turn in for most corners.
2. Hit all your apexes. Consistently hitting your apex and track out marks tells you can start to push a little harder, Inconsistency hitting these marks means you are possibly pushing harder than you are ready for and at risk of a large enough mistake that you leave the track,
3. The correct place to start rolling onto the throttle is always the apex. If you can't get on the gas there and stay on the gas your apex is too early. If you don't need all the track out room your apex is too late. Late apexes are safer, but the fastest line is the earliest possible late apex. That is the apex point where, when you hit it and go to gas, you can stay on the gas without any lifting and barely keep the car from going "too wide" at the track out. You pick what "too wide" is based on how consistently you hit your track out mark. If your track out varies from lap to lap you need to aim to track out a couple of feet from the curb to allow a margin of error. With practice you aim to track out at the curb, where the curb itself is your margin of error. If you are really confident you aim to track out on the curb, unless it is too much of a bump or traction loss.
These are general comments that apply to most "stand alone" corners. "Connected" corners are all different and these ideas may not apply. Hope they are not too obvious.
mikelanzetta
Apr 25, 2016 08:48 AM
