Genrad GDS3500 WDS Docking Station
Old Sep 29, 2018 | 11:25 AM
  #481
JagV8's Avatar
Lack of upload might - I'm unsure - be due to the low post count you have.
Old Sep 29, 2018 | 11:29 AM
  #482
flasher's Avatar
Thank you, i see the pictures are in my album now (uploaded several times) but now i can't move them to this post - can i mark them for public view somehow ?
Old Sep 30, 2018 | 11:30 AM
  #483
JagV8's Avatar
I don't actually know, sorry!
I think you only need 10 or 15 posts so I suppose a few more will get you there. It's to reduce spam, but sadly does have this side-effect.
Old Oct 1, 2018 | 06:39 AM
  #484
flasher's Avatar
Because my post count is still too low to upload some pictures of my Iveco IT2000 / GDS3500 tool with some details about the USB connector and surrounding parts i add this post to reach my minimum post count (10 posts ??)…..
Old Oct 1, 2018 | 06:41 AM
  #485
flasher's Avatar
Thank you for all info i already found on this great forum and thanks to Bob and Yvo for their great help to get my GDS3500 up and running.....
Old Oct 1, 2018 | 06:46 AM
  #486
flasher's Avatar
I already ordered some CR2450 batteries + battery holders to replace the Original CMOS battery - i assume the type number is correct when i look at the size of the battery ?
Can i just put it in parallel with the present BIOS battery to avoid further disassembling of the touch screen ribbon cable and other connectors ?
Old Oct 1, 2018 | 06:53 AM
  #487
flasher's Avatar
i just tried to upload some pictures from my album but i still don't succeed - can somone explain what conditions have to be met before i can post pictures ?
Old Oct 1, 2018 | 07:57 AM
  #488
flasher's Avatar
Default some pictures finally....
Old Oct 1, 2018 | 08:00 AM
  #489
flasher's Avatar
i forgot the keyboard....
Old Oct 1, 2018 | 10:13 AM
  #490
flasher's Avatar
i just compared the region of the USB connector of my Iveco GDS3500 with this picture of a WDS unit but there are slight differences regarding the pcb layout, if someone needs values of certain components i can check them if unreadable on the pictures....
Gert
Old Oct 2, 2018 | 03:43 AM
  #491
y.roos's Avatar
This is really interesting! We always thought it would be possible to have a USB connector at that space on the board - and there it is! I'm going to compare your pictures with my pictures of the Ford WDS - looking if anything else is different....many thanks!
Old Oct 2, 2018 | 08:07 AM
  #492
flasher's Avatar
Hello Yvo,
the upper picture is the pcb of a Ford WDS which i copied from a post on this forum so you can compare the two pcb's in the post above….
Old Oct 2, 2018 | 08:25 AM
  #493
flasher's Avatar
Well today i hit the jackpot !
i was able to buy a complete WDS kit with dockingstation , PTU, all cables, cd's doumentation + a complete IDS system + a vintage FDS2000 system also with all cables, cd's, documentation, folders etc.
All items are in mint condition and most tools were packed in their Original boxes !
It took me a ride to Belgium but it was well worth the effort, my cable problem is solved at once now !
It will take quite some time to do a inventory of all included stuff but it's a nice job !
I will let you know when i find any rare parts or software, i'm in the right spot on this forum...…
Old Oct 2, 2018 | 10:30 AM
  #494
flasher's Avatar
i just tried to power up the PTU in the docking station but it seems the power supply only supplies power for 1 second and then it shuts down.
Is this a known problem with the docking station and has someone found a solution for this fault ?
Can i exchange the power supply with another one from an old computer ?
The PTU gives me the 2217 fault code due to the dead battery - i will exchange that first to see how the machine works with a fresh battery….
Old Oct 3, 2018 | 09:38 AM
  #495
motorcarman's Avatar
Top Answer: 3
If you go back through the hundreds of posts in this thread, you will find ways to power the docking station with different power supplies.
Dead battery packs will cause all sorts of issues.
bob
Old Oct 3, 2018 | 09:46 AM
  #496
flasher's Avatar
Hello Bob, thank you for your reply- i already found some answers in this thread in the meanwhile, right now i'm charging a fresh battery pack and i will check if it makes any difference…..
Old Oct 3, 2018 | 11:10 AM
  #497
JagV8's Avatar
Congrats!
Old Oct 5, 2018 | 08:48 PM
  #498
Top Answer: 3
I would pay an enormous amount of money for all that you have!!!!!!!!!!!!!!! Congratulations on the find. I hope you help locals with diagnostics!!
bob
Old Oct 5, 2018 | 09:15 PM
  #499
Cambo's Avatar
If you're interested in selling the FDS2000 , I might be interested.
Old Oct 6, 2018 | 02:33 AM
  #500
flasher's Avatar
you have PM.....
