New SDD Engineering Access tool
Old Nov 23, 2022 | 12:04 PM
Rhys Morgan's Avatar
Default New SDD Engineering Access tool
Hi All,
We have created a new tool to give SDD engineering access. It is in its early phases, but is currently giving out the same passwords from the virus laden tool. Feel free to give it a test and feedback any issues, code is all open source. Big thanks to Jules for the doing the figuring out of the keys etc, I've done the easy part of converting to javascript and turning into an app.
Theres an executable for windows, mac and linux so choose your flavour!
https://github.com/rhysmorgan134/SDD...lator/releases
Old Feb 23, 2023 | 11:10 AM
Ura's Avatar
Ura
добрый вечер,необхожимо скачать весь список файлов или нет? благодарю заренее
Old Feb 23, 2023 | 01:31 PM
You only need to download the correct one for your operating system (exe for windows, dmg for mac)
Old Feb 27, 2023 | 03:33 PM
james5's Avatar
Originally Posted by Rhys Morgan
Hi All,
Hi Rhys
I have a Mongoose Pro and a JLR V164 SDD (no patch yet) and I want to use it fully for my 2007 jaguar x type (special functions, TOPIX, Engaging mode, etc.). Do you have a video explaining how to use the CCF TOOL and the JLR SEED CALCULATOR please? How long do the codes stay? Thank you
Old Mar 1, 2023 | 12:04 PM
Ura's Avatar
Ura
hello dear James ! it is very simple to use, you need to register a vin and a code, then generate a password, a password for the session, after completion you need to generate a password again, everything is simple))))
Old Mar 1, 2023 | 12:06 PM
Ura's Avatar
Ura
Originally Posted by james5
Hi Rhys
please write whether this calculator generates correct passwords for you? I personally do not, I found an old working calculator but with a virus
Old Mar 29, 2023 | 12:54 PM
Mayfair86's Avatar
I was looking forward to being able to use this tool but unfortunately it wont install as it states it only works on X64 windows, however SDD works on X32? Any ideas?
Thanks Josh
Old Mar 30, 2023 | 09:47 PM
Aarcuda's Avatar
Ive got a stupid question
how do I access the tool in sdd? I can get the password generator to generate a password I can get into SDD and enter the correct credentials but I don’t see anywhere that I can make any changes to the vid block or CCF? I have an 06STR and I believe that’s still uses the old vid block. Do I get no access because it’s trying to look for a CCF? Or tell me what you put in password it’s generated into the SDD section four opening up that tool does it just open up the tool or do I have to go to recommendations or options page or watt? I put the password in. Enter and it doesn’t look like anything changes. I’m using version 131 SDD .
Old Jun 28, 2023 | 11:46 AM
fivel's Avatar
If you can install Python on your system (i.e. its not XP or earlier) you could try using the python version: https://github.com/5555l/sdd_engineer_code
Old Jun 30, 2023 | 11:04 AM
Ura's Avatar
Ura
good evening friends if you need a calculator for the engineering menu, I'm ready to fill it up again, it only works with the antivirus turned off
Old Apr 25, 2024 | 12:35 PM
-CISCO's Avatar
Default Calculator
Hi
Im interested in the SDD calculator. Thanks in advance.
juarezmexico@aol.com
Old Apr 25, 2024 | 12:42 PM
-CISCO's Avatar
Post Sdd seed password
I'm running SDD162.00. V347. Have installed the calculator and it generates the password, when I input the password in SDD it does not turns the yellow bar in the bottom, What am L doing wrong?
Thanks a in advance!
Old Apr 25, 2024 | 04:19 PM
fivel's Avatar
Are you using the Rhys's tools or the python code to generate the password and what model and age of car are you using it on?
Old Apr 25, 2024 | 05:43 PM
-CISCO-'s Avatar
Banned
sdd-engineering-access.Setup.01.exe rhysmorgan134/SDD-Engineer-Mode-Calculator. Mi truck is a 2007 Land Rover LR3
Old May 1, 2024 | 09:11 AM
-CISCO-'s Avatar
Banned
Well... this is a Jag forum, all I have is a JAG 4.4l engine and ZF6hp transmission. I'm missing the body lol
Old May 22, 2025 | 01:07 AM
HeigoT's Avatar
Hello, I just wanted to post this on to the forum to give back to the community:
I searched for coded access keygen and didn't want to risk with downloading trojans to my machine. Finally I found python file from the same thread here. I did not know how to run this python code so I gave it to chatgpt and made javascript/html versions with GUI. It basically runs on all javascript enabled browsers locally.
Feel free to try this out, there are 2 html files in attachment. One which is xp compatible and should be better suited for older browsers etc.
It seems to be working correctly, but for some reason I think I still didn't get coded access to my car, I think I have problem with the Mongoose Pro+ OBD cable. So if it works on your system please leave feedback, thanks!
File Type: html
Old May 31, 2025 | 03:56 PM
KurtC's Avatar
I just came across this post and noticed some of the questions might be answered in my post providing instructions for activating a rear park assist camera in SDD. I used Rhys Morgan's seed calculator and my instructions describe and show pictures of how to use it. Thanks Rhys for providing the seed calculator! I find it to work flawlessly.
Here are instructions: Activation and Installation of Rear Park Assist Camera in 2009 Jaguar XKR
lstoch
Dec 7, 2021 11:27 PM
jean HJ
Dec 3, 2021 01:24 PM
Dan Fuller
25
Sep 18, 2020 08:29 AM
robbing
Aug 27, 2020 01:25 PM
peterv8
Sep 28, 2017 11:30 AM
