which oil filter do you use ? K&N , MANN , OEM, MOBIL-1 ect.
Old Jan 29, 2009 | 09:42 PM
cincinnati's Avatar
Default which oil filter do you use ? K&N , MANN , OEM, MOBIL-1 ect.
which oil filter do you use and why ?
1. K&N
2. MANN
3. OEM
4.MOBIL-1
5 other ?
Old Jan 29, 2009 | 09:45 PM
cincinnati's Avatar
Default RE: which oil filter do you use ? K&N , MANN , OEM, MOBIL-1 ect.
i'll start its either K&N or OEM for me.
K&N i pick because of the company's r&d dept. and the 20+ years of producing good products.
OEM well i choose that beacuse its manufactured to specs of the vehical
Old Jan 30, 2009 | 01:27 AM
Green Machine's Avatar
I use the K & N first because it's a good filter and second because of the 1" nut they welded to the end of the can which makes it very easy to service in tight spaces.
Old Jan 30, 2009 | 05:51 AM
joey4420's Avatar
Normally I would use K&N, but for my 4.0 03 XJ8, they do not list a filter (Oil that is). So I bought a Mobil One.
Old Jan 30, 2009 | 07:04 AM
Thermo's Avatar
Veteran: Navy
MOtorcraft (OEM) for me. Costs the same as any other filter out there. Was what the car was designed around.
Old Jan 30, 2009 | 08:58 AM
chadmc5c's Avatar
I've seen a web page where the guy (well at least I think its a guy) bought all the different mfg oil filters for the same application and then cut them open and did a spreadsheet on the type of check valve, number of pleats, surface area, filter material, etc. It was quite interesting to say the least.
I have been using NAPA gold and silver for years on most of my vehicles and have been happy with them.
I also learned that like batteries, there are alot of filters made by the same mfg for several different retailers.
I NEVER use Fram.
Good topic!
Chad
Old Jan 30, 2009 | 09:59 AM
Doug's Avatar
ORIGINAL: chadmc5c
I NEVER use Fram.
Good topic!
Chad
I've read the same write-up. I'll admit that, since reading it, I don't use Fram filters on my Jags. I feel a bit silly, though, because I used Fram filters forumpteen years with no ill results....at least none that I could see, feel, or measure. I'll still use them on the family beaters if that's what's on sale that particular day <grin>
Nowadays I use Jag OEM just because it makes me feel good. I've heard, though not confirmed, that Jag has changed filter vendors 2-3 times in the last 10 years or so. I don't know who actually makes 'em. Cooper ?
PS-If I run out of OEM I use Bosch or AC Delco.
Old Jan 30, 2009 | 11:52 AM
Dennis's Avatar
ud
What is this..the 100th thread on this topic?
Factory
Old Jan 30, 2009 | 12:22 PM
ken@britishparts.com's Avatar
You just can't wear out some topics. [&:]
Old Jan 30, 2009 | 09:18 PM
1995XJ609's Avatar
Well, I might be crazy, but I'm using Wix. Supposedly they are good filters ...
Old Jan 30, 2009 | 09:34 PM
ArmyJag's Avatar
Wix for me as well they are the same as the Napa Gold filters. I also like the mobil-1 filters.
I agree 100% that fram filters are crap. Put one on your land rover and the first surprise you'll have is your oil light greeting you on start up. Change the filter to a quality one and it goes away.
Old Jan 31, 2009 | 09:17 AM
chadmc5c's Avatar
No doubt due to the crappy check valve or lack thereof.
The NAPA gold for one of my BMW applications was a Mann so NAPA is outsourcing to whatever for different applications
Old Jan 31, 2009 | 08:51 PM
whiteSTR's Avatar
Motorcraft... Mobil-1s are excellent and are designed to be used with synthetics, K&Ns are decent.. But, OEM is definitely the best..
aholbro1
Dec 29, 2024 06:46 PM
Johncy2000
Dec 22, 2017 04:32 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
1964Daimler
Sep 9, 2015 11:28 AM
