Panoramic Roof Jaguar Stamped?
Old Jul 6, 2025 | 09:40 AM
Harlo's Avatar
Default Panoramic Roof Jaguar Stamped?
Hello,
I've been chasing a roof water leak on my sportbrake and believe the roof glass may have been replaced. Every other piece of glass is stamped that it is from Jaguar with exception of the roof, wondering if anyone knows if the panoramic roof glass also had the Jaguar stamped on them?
I've been reading here about others that have had troubles with panoramic roof repairs/replacements and I'm sick thinking I have to go through the process but if I must so be it.
Thank you.
Old Jul 6, 2025 | 10:33 AM
clubairth1's Avatar
Community Influencer
Hard to say with zero car details?
Old Jul 7, 2025 | 05:20 AM
Harlo's Avatar
2018 xf sportbreak.
Old Jul 7, 2025 | 08:42 AM
Coventry Foundation's Avatar
Harlo does your sportbrake have load racks installed? If so look there first.
Old Jul 7, 2025 | 01:52 PM
Harlo's Avatar
Yes, I do have tracks. I did apply water from the outside of the rack with no water penetrating.
I really feel the roof had been replaced as the gap from the body panel to the glass on the drive side is noticeably larger than the passenger side.
There is no Jaguar stamping on the panoramic glass which I find curious as all the other glass does have that stamping from Jaguar.
Old Jul 8, 2025 | 09:17 AM
Will look at our sportbrake's glass. Where does the water show up inside?
Old Jul 8, 2025 | 09:37 AM
Harlo's Avatar
It's running down the A Pillar on the driver's side and exciting through the vent and polling in the footwear.
after running water up the A pillar I didn't experience a leak until I reach the area where the panoramic roof begins above the driver's seat.
I'll take some pics tonight if it's not raining and post. I'll also do the passenger side to highlight the difference in the gap containing the rubber piece between the body panel and the glass.
Thank u very much.
Old Jul 8, 2025 | 09:42 AM
Harlo's Avatar
I must say I love driving this car, it's fantastic. Good power (always want more), handling and comfort with great support under spirited driving.
Have you done any modifications to yours?
Didn't realize how few where built to after purchase.
Old Jul 8, 2025 | 12:15 PM
We will check the glass but the leak we had came from the front mount of the load carriers---------on the drivers side and it ran down the a post. Rovers have this issue often so the techs say.
Old Jul 8, 2025 | 05:26 PM
Harlo's Avatar
Hope these are clear enough. I tried to show how the passenger side rubber seal is basically a "v" between the glass and body panel whereas the driver side is just laying flat. Hope this makes sense.
I don't see how to remove the roof rail from the exterior so I'm assuming you need to remove the headliner check to see if that may be the issue.
Old Jul 8, 2025 | 05:28 PM
Harlo's Avatar
Think the leak photo got cut from the post.
Old Jul 9, 2025 | 12:53 PM
We checked our 19 and the glass is not marked. As you said all other glass is marked. Best of luck!
Old Jul 9, 2025 | 02:25 PM
Harlo's Avatar
Thank you checking and feel I'll need the luck.
Ron1
Nov 11, 2021 10:28 AM
SonofGaladriel
Dec 29, 2019 09:09 PM
malc4d
Dec 11, 2014 08:45 PM
vincent661983
Jun 28, 2012 12:32 PM
Simprof
Jul 5, 2011 03:31 PM
