Solenoid valve
Old Oct 27, 2023 | 09:13 PM
Immortalsoul11's Avatar
Default Solenoid valve
Good evening. I have a jaguar s type 2000.
Where is the solenoid valve for the air injection at?
Part number: LJA1530AA.
Old Oct 28, 2023 | 02:06 AM
JagV8's Avatar
Air injection? Either I don't know what you mean or I'm pretty sure you don't have it.
Where is the thing in the photo from / where is/was it connected?
Make sure you have the Electrical Guide from this site / JagRepair.com - Jaguar Repair Information Resource
Old Oct 28, 2023 | 04:28 PM
clubairth1's Avatar
Community Influencer
Do you have code P0065 by chance?
I believe the early S-Type and the Lincoln LS both had air assisted fuel injectors?
Kind of a stop gap modification to increase fuel economy. There are passages (Pipes, Hoses) from the throttle body to the base of the injectors. Under idle and other high vacuum situations the valve shown above opens allowing air to go to the bottom of the fuel injectors. This addition air is to swirl around the fuel injector pintle at idle. Supposedly increasing the atomisation of the fuel increasing fuel economy and reducing emissions.
Now it must not have been very effective because after the 2000 model year I believe it was dropped permanently by both Jaguar and Lincoln. A few other cars also used these air assisted fuel injectors. I know nothing about them but I "think" this is what he is working on.
Old Oct 28, 2023 | 08:58 PM
it’s a photo of the air injection I brought. Took my car to oreiley and the gave me a code and told me to buy this device
Old Oct 28, 2023 | 08:59 PM
That’s a bummer. Will I (a non mechanic) be able to change this myself?
Old Oct 29, 2023 | 06:17 AM
clubairth1's Avatar
Just swapping random parts seldom works.
I would research what code you have. O'rielly is fine but they don't know anything. They hire anybody and they just look at the code and read what the it says. They don't understand cars or engines. So the value of their advice is zero. With people like that use them to get the code.
The actual code number as you have posted nothing of value so far?
No car or engine info or miles or even what's going on? How can anybody help?
I would read this forum and then start a different thread on what your car is actually doing?
Is it driving? Do you have a check engine light on the dash?
Start at the beginning and work thru the problems.
A used Jaguar is NOT for someone who can't DIY the repairs! But this forum does have much information if you search.
First use this forum and the UK forum. See if you can find someone with a similar problem.
Old Oct 29, 2023 | 11:37 AM
Where were you a month ago when I got the car? 😆
Old Oct 29, 2023 | 12:24 PM
clubairth1's Avatar
Yes but you can learn to do it if you want? It's not terribly hard either. As you noted most if not all the answers are on the forum.
Give it a try?
I mainly DIY because of the terrible work I have had done over the years at dealers and other shops. Not to mention the astounding costs! I paid for an oil change at a Jaguar dealership. He started at $225! After I made some noises he helped me out and charged $175! Now on my XJR the oil is changed by opening the hood. Unscrewing the oil filter and sucking the oil out of the engine. Takes about 20-30 minutes. No need to get under the car or even to get dirty! Maybe $70 for the oil and filter.
No one cares about your car more than you do!
I found the same with managing my own money. If it's yours then you will feel it's important. If it's NOT yours it's just a job.
Old Oct 30, 2023 | 07:38 AM
Vee's Avatar
Vee
You started your post by identifying your model year, so you’re light years ahead of many other posters here!
Get out of this forum, and post in the s-type forum and you will undoubtedly get all the information and help you need.
I have owned an XJS since 2010. The help and support you will find here will give you the confidence to do most any repair! I don’t have a garage, just a driveway, and it’s my daily driver, so all projects must be completed by the next workday. This forum has allowed me to prepare for all projects to make sure it gets done.
This General forum is too non-specific, so you may not get all the answers you need, but if you go to the right sub forum, you’ll be diagnosing and wrenching yourself in no time! Just be safe!!!
Old Oct 31, 2023 | 07:59 AM
clubairth1's Avatar
Good advice from Vee as the individual forums contain the experts on that particular model.
Tomtommy
Dec 18, 2018 10:55 AM
Ohlert
Mar 18, 2018 04:51 PM
Gameblaster1
Mar 7, 2014 11:17 AM
DrDodge
Sep 25, 2010 04:56 PM
