Supercharger belt
Old Dec 1, 2018 | 07:38 AM
User 070620's Avatar
Default Supercharger belt
Hi , my 4.2 xkr have this supercharger belt:
2W93 8620 EB
i have a stage 2 upper pulley.
Where i Can find It a Little more short belt ? Part Number?
Thank you
Old Dec 1, 2018 | 03:15 PM
jackra_1's Avatar
I presume your belt is slipping?
I have a similar setup and bought my super charger belt on Ebay and no slipping whatsoever.
Its the standard belt for a 2005 XJR.
Is your idler pulley setup working properly?
Old Dec 3, 2018 | 01:25 AM
not slipping. Only that will be better a little more short belt
Old Dec 3, 2018 | 07:23 AM
jackra_1's Avatar
If your existing belt is not slipping then I do not understand why you want a "tighter" belt?
Old Dec 3, 2018 | 07:29 AM
I WANT IT BECAUSE WITH STAGE 2 SMALL UPPER PULLEY IT WILL BE BETTER THAN OEM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
understand now?
Old Dec 3, 2018 | 07:33 AM
jackra_1's Avatar
Why would it be better? If it is not slipping and is moving the pulley with no problem what benefits would a tighter belt provide?
Old Dec 3, 2018 | 08:33 AM
JagV8's Avatar
None I can think of. Hoping to hear...
Old Dec 3, 2018 | 08:43 AM
I have the whole new engine and the belt, even if it does not slip, is old and I have to replace it. And since I have to replace it, I thought I'd put a slightly shorter one.
Old Dec 3, 2018 | 08:51 AM
jackra_1's Avatar
Ok understand now...
Problem is that on belts that I see advertised they do not give measurements just "compatible vehicles".
Teck4Jag
Sep 22, 2017 02:26 PM
Ragn0r
Apr 18, 2016 05:49 AM
XKR2000
Sep 5, 2014 07:57 PM
Bacardi 151
Jun 1, 2012 03:16 PM
2000blackxkr
Sep 13, 2009 10:28 PM
