ZF 4HP22 fitting
Old Feb 8, 2024 | 02:08 PM
jknies's Avatar
Default ZF 4HP22 fitting
Hello all. I'm working on a ZF 4HP22 transmission and have run into a snag getting one part. Its the fitting that comes out of the trans for the upper cooling line. The fitting screws into the trans is 18 x 1.5 mm. Then the coolant line screws onto that which is also 18 X 1.5mm. The Stücklistennummer on the trans is 1043 010 496 and the serial number is 0853680. Any help would be greatly appreciated. Thanks, Jack
Old Feb 8, 2024 | 05:31 PM
clubairth1's Avatar
Community Influencer
Can you tell us what car your working on? Is it a Jaguar?
Old Feb 9, 2024 | 08:51 AM
jknies's Avatar
Sorry, its a 1988 BMW 635csi. I know this is a Jaguar forum but I figured it was worth a try. Hoping they would be similar transmissions and someone could have some insight. Thanks again
Old Feb 10, 2024 | 12:37 PM
clubairth1's Avatar
No problem but if you knew what models of Jaguar used this transmission I can look it up in the electronic parts catalog to see if maybe Jaguar offers that part separately.
I do have one suggestion?
I like and use this place and all they do is ZF stuff. I would be willing to bet they would have an answer for you?
You did not post where your at so I not sure this will work for you as they are in the US?
ZF Parts
Klaus use to be easy to talk to but I have heard that they prefer E-Mail over phone calls?
Now you do have an older 4 speed version and The CTSC web site shows stuff for the 5,6 and 8 speed versions. So I am not sure how many 4 speed parts they have?
Old Feb 10, 2024 | 01:09 PM
motorcarman's Avatar
The 1988/89 3.6 liter XJ40 uses the ZF 4HP22.
I have the ZF service manual.
File Type: pdf
Old Feb 11, 2024 | 10:31 AM
jknies's Avatar
Thanks clubairth1, I sent an email off to him and will see what happens. I looked through that entire manual motorcarman and only saw 2 pics with the line in it and no part numbers though, Thanks for trying. This is a great site, alot of people willing to help out. Thanks again
Old Feb 12, 2024 | 08:25 AM
clubairth1's Avatar
If you do find the part it would be great if you could stop back and finish this thread up?
It is a rare one but maybe someone with that year of transmission will be looking for that part too?
Old Mar 9, 2024 | 07:12 AM
jknies's Avatar
Well I finally found the fitting I needed. The aftermarket BMW sites were no help. Countless emails to ZF were no help since the trans is so old and they said it was a BMW part anyway. Three trips to the dealer were no help either. To add insult to injury all the fittings I ordered had to come from Germany so probably 2 months wasted waiting on the wrong part. I finally found it on ebay. Its from Adaptall and the part # is 9001-18-18. Thanks for everyones help
Chris Steineger
XK120 XK140 XK150
Oct 23, 2018 02:52 PM
felinecat
E type ( XK-E )
Apr 28, 2015 07:02 PM
metalmarty
Nov 3, 2014 06:42 PM
charliepace
Feb 1, 2011 08:20 PM
jensenguy
Aug 14, 2009 12:43 PM
