Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Anyone know what CFM goes through an XJR or XKR intake?
Old Aug 14, 2012 | 08:38 PM
WaterDragon's Avatar
Default Anyone know what CFM goes through an XJR or XKR intake?
I'm curious of what the flow rates are (max) through a stock intake system on a x308 XJR or XKR 4.0.
Any ideas of a number in cfm through the engine at max boost/redline?
Old Aug 15, 2012 | 03:49 AM
steveinfrance's Avatar
Avos is your man for this but (theoretically) at max boost 11.6 psi and 6000 rpm
it will be 4 x 6000 x (14.7+11.6)/14.7 litres/min = 43,000L/min or 1520 cfm
Old Aug 15, 2012 | 08:25 AM
Somewhere I'm seeing a Mars rover smashing into the surface in that PSI to liters conversion
Old Aug 15, 2012 | 08:40 AM
Theoretically as I said a 4L engine displaces 4L air per rev
so a normally aspirated engine at 6000 rpm displaces 4 x 6000 = 24,000 L/min
1 cfm = 28 lpm
so that would be about 850 cu ft/min
But the supercharger is adding 11.6 psi boost.
It needs to aspirate more air than the 24,000 L /min going through the engine
The air inside the engine is at atmospheric pressure (14.7 psi) + 11.6 psi = 26.3 absolute so the volume of air at 14.7 psi aspirated by the supercharger
= 24,000 x (26.3/14.7) - yes I do apologise for the mixed units but psi/psi is a ratio, a non dimensioned number.
It makes no difference if the pressures are in psi, Bar, Pascals or whatever provided both units are the same.
That comes to about 43,000 L/min.
But it is theory. There will,of course, be losses everywhere so the true flow would be less
Safe landing though!
Old Aug 15, 2012 | 09:40 AM
I was just lamenting the fact and making fun of our NASA engineers that even after they drilled the lander into the surface of Mars, we STILL are not going to change to the metric system...
So what would the CFM be at 18 psi boost?
Old Aug 15, 2012 | 10:03 AM
Theoretically 24000 x (14.7 + 18)/14.7 = 53,400 lpm, 1885 cfm.
That's a 12 foot cube!!
My guess is, in the real world with losses and adiabatic heating it would be nowhere near this.
Just out of interest 43000L/min going through a 10 cm dia tube would have a velocity of about 30 km/hr
Old Aug 15, 2012 | 10:04 AM
Mikey's Avatar
It's actually every second rev being that this a four stroke engine so at redline that would be 12,000 L/min. Typical VE for a non-boosted engine would around 70-90% of that and boosted might be around 130-180%.
Old Aug 15, 2012 | 10:12 AM
Aaargh, I was calculating as a simple compressor. Stupid boy!!
Halve everything, thanks Mikey.
12000 x 1.8 = 21,600 so the calculated figure of 53000 divided by two isn't far off.
Old Aug 15, 2012 | 10:29 AM
Let me see if I can keep up...
So as of right now we are saying at 18psi we would see something in the neighborhood of 1000 cfm?
Old Aug 16, 2012 | 02:43 PM
Yes, absolute maximum is 900 cfm, less in the real world.
Old Aug 16, 2012 | 03:09 PM
OK,
Thank you for the info, I'm handing the figures over to Dr. Bunson Honeydew to see what he can do with it.
"At Muppet Labs, we bring science to the streets"
Old Aug 18, 2012 | 10:27 AM
XJR-0220's Avatar
Im sure beeker will screw it up somehow lol
Old Aug 18, 2012 | 02:22 PM
Poor Beeker doesn't screw things up, he just always gets it when prototypes don't work as intended. Just like Wyle E. Coyote
Old Dec 24, 2012 | 01:53 PM
aldol's Avatar
need to divide by 2 as there is one intake stroke every 2 revolutions
Old Dec 24, 2012 | 02:00 PM
plums's Avatar
As was pointed out and corrected four months ago.
Old Dec 25, 2012 | 02:17 PM
aldol's Avatar
sorry i had not gone that far down
Old Mar 17, 2013 | 10:55 PM
Count Iblis's Avatar
The AJ27 supercharged variant will flow 1100 Kg/hr of air.
The later 4.2 litre AJ33/36/34 will flow about 1300 kg/hr of air.
This is measured on the dyno using the AFR and a coriolis fuel flow measurement.
I'm sorry but we were all metric at Jaguar.
Old Mar 17, 2013 | 10:57 PM
The peak VE for the NA engine was about 95% at peak torque and about 80-90% at peak power.
The peak VE for the SC variants was about 135-140%.
clubairth1
30
Sep 3, 2025 04:38 PM
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
FeralJag
Jan 11, 2016 05:07 PM
