Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
MY NEW RSR Jaguar ENGINE ARRIVED !
Old Mar 30, 2018 | 10:34 AM
User 070620's Avatar
Default MY NEW RSR Jaguar ENGINE ARRIVED !
Today start my new project.
Just arrived from Tony Gentilozzi of RSR JAGUAR USA his racing block 4.8L for my xkr coupe year 2005.
Big bore with 92mm pistons .
This is real an exciting day for me !
I'm probably the only private person in the world to have it. ... of this car:
In photos : oem vs RSR JAGUAR
Attached Thumbnails MY NEW RSR Jaguar ENGINE ARRIVED !-img-20180330-wa0014.jpg   MY NEW RSR Jaguar ENGINE ARRIVED !-img-20180330-wa0012.jpg   MY NEW RSR Jaguar ENGINE ARRIVED !-img-20180330-wa0016.jpg   MY NEW RSR Jaguar ENGINE ARRIVED !-img-20180330-wa0009.jpg
Old Mar 30, 2018 | 10:44 AM
Looks good!
I'm sure there will be lots of pics and info on the build.
Old Mar 30, 2018 | 11:51 AM
JagV8's Avatar
O M G. . .
Old Mar 31, 2018 | 09:29 AM
XJR-99's Avatar
I don't know but for me that looks like standard V8 block...just Darton-sleeved to 92mm? Like some others here in the forum have done.
RSR has made some special bloks for their own racing engines: https://www.jaguarforums.com/forum/j...tom-end-96033/
Old Mar 31, 2018 | 01:18 PM
avos's Avatar
It looks indeed like a normal standard bored out block, cleaned but take it its used by an old lady who never pushed it ;-)
Maybe the price was ok comparted to make it yourself, that's for duece2000 to tell, it depends also on possible other parts not shown in the picture as only a bare upper block is shown.
There is certainly potential now as I have experienced, its just the intake part that will be lagging behind if he doesn't throw away the Eaton.
Old Mar 31, 2018 | 02:16 PM
Nice - look forward to seeing the build progress!
Old Mar 31, 2018 | 10:23 PM
Tijoe's Avatar
Looks like my block that is sleeved to 92mm....
Attached Thumbnails MY NEW RSR Jaguar ENGINE ARRIVED !-block.jpg   MY NEW RSR Jaguar ENGINE ARRIVED !-block2.jpg
Old Apr 1, 2018 | 12:37 AM
avos's Avatar
Very familiar site
What's odd is that as far as I knew, RSR was using the AJ133 engine in the car shown.
Attached my 92mm bore engine, as you can see my builder took a different approach to the top flange.
Old Apr 22, 2018 | 05:03 PM
JagSTR2004's Avatar
Nice! I am beginning to feel 4.2 is too small now....Awesome sound that Gt2 XKR has and avos is right, it uses the NA 5.0 AJ133 tuned up apparently. I found some info here: https://www.google.co.uk/amp/s/www.t...73325.amp.html
Awesome that RSR are selling parts to private customers too. I always wondered what they did to their XFR to hit 225mph at Bonneville. I've seen a tuned XFR easily hit 186mph, but another 39mph at those speeds must take a lot of extra power.
Old Apr 23, 2018 | 02:28 AM
JagV8's Avatar
Old Apr 25, 2018 | 11:57 AM
avos's Avatar
They where making lots of customs parts, even full custom engines for our cars, like a 4.5 engine which consisted of an own developed block, new internals obviously and some more for $25k+ which isn't even that high actually if you count it all up. They may still do some, here is a link on this forum:
https://www.jaguarforums.com/forum/n...-racing-92748/
Old Sep 12, 2018 | 03:41 AM
https://www.facebook.com/luca.manni/videos/10217015276037509/
Old Sep 12, 2018 | 10:13 AM
avos's Avatar
Looks good!
I also wanted to have the same shape of pistons from CP, but somehow my builder didn't do that as you can see for mine.
For which piston material did you go, 2618 or 4032?
Old Sep 13, 2018 | 01:56 AM
[QUOTE = avos; 1961109] Sembra buono!
Volevo anche avere la stessa forma dei pistoni di CP, ma in qualche modo il mio costruttore non l'ha fatto come puoi vedere per il mio.
Per quale materiale del pistone sei andato, 2618 o 4032? [/ QUOTE]
I finally did something that you like too! I'm happy!
we have sent the original pistons to this specialized company : CPS - Costruzione Pistoni Speciali - Torino
and they have them rebuilt more big . I don't know what kind of material they used but on their site they are listed as "competition pistons" so I guess it's the best!
ah ... I forgot. I made them build 9. One to put it in the window of my dinner room along with the original piston! :-)
Old Sep 13, 2018 | 02:41 AM
https://www.facebook.com/luca.manni/videos/10217416995320240/?l=687244587005878664
Old Sep 13, 2018 | 10:13 AM
Tijoe's Avatar
Pistons look fantastic. Can you weigh your spare one and post the weight? (Plus weight of the rings?) What is the compression height?
(Perhaps they provided you with an inspection sheet that lists all the pertinent data.)
Thanks. Joe
Old Sep 16, 2018 | 01:55 AM
avos's Avatar
Better (ie Best) depends on what you require, here is a site that explains the differences between the materials
2618 vs. 4032 Piston Material Differences
I choose the 2618 material, mainly as I wanted to be better protected due to the higher pressures/temps that the engine would experience going up the HP road, so for that part it was the best choice.
One disadvantage is they are loud when cold, and as I am not hunting anymore for higher HP levels and as I have other rides now, I would actually want to switch to the 4032 pistons one day when the budget permits...
Old Sep 17, 2018 | 07:09 AM
Old May 2, 2019 | 03:52 AM
Old May 4, 2019 | 06:13 AM
AJ16er's Avatar
@deuce2000 - what are the hp/torque/redline specs on your engine?
