Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Allowing editing of own posts
Old Sep 12, 2012 | 06:25 AM
gunnar_xj6's Avatar
Default Allowing editing of own posts
I notice people who submit posts are not permitted to edit them.
Whis can be very annoying and an unneccessary restriction. It is not uncommon th make small spelling mistakes or use wording that one could want to correct in order to accomplish a higher quality post. Please consider changing this policy. It helps JaguarForums end up with a higher quality material.
Old Sep 12, 2012 | 06:40 AM
joycesjag's Avatar
gunner, in the bottom right of the text box that you have posted is an "edit" button.
Good practice is to reread your post before clicking on the "post" button. If you have made a mistake after posting, you simply click "edit" and correct mistake or add to post.
Hope this helps.
You as a member can only edit your post not the title.
Old Sep 13, 2012 | 04:06 AM
plums's Avatar
If you use the "New Reply" or "Go Advanced" buttons, you also have the "preview post" function.
Old Sep 13, 2012 | 02:03 PM
Just one caveat to the advice above, New members do not have the Edit facility until after the short qualifying period.
By my calculations, Gunnar should be good to go.
Old Sep 14, 2012 | 10:44 AM
gunnar_xj6's Avatar
Ok thanks for clarifying, so it seems new members have a grace period.
I still cannot see any edit button for this post:
https://www.jaguarforums.com/forum/x...23/#post579998
Or will the Edit button also expire after some period for new posts ?
Old Sep 14, 2012 | 10:51 AM
steveinfrance's Avatar
Once you get the edit privilege you can edit any of your own posts - there's no expiry time.
Another useful thing is to use the 'report post' button if you accidentally post twice - just explain what's wrong and one of us will delete it.
Old Sep 14, 2012 | 10:55 AM
Gunnar, if you post in the new members section our all powerful Admin will likely upgrade you to unrestricted access.
Old Sep 14, 2012 | 10:57 AM
Gunnar - what you have been told above is correct.
You are still a "registered member" and have not as yet fulfilled the criteria to make the jump to "Full Forum Acess" member.
I can't see an intro in the new member section for you?
Generally, those who take the time n trouble to make an intro are updated within a day or so, sometimes within an hour or so even.
I have now upgraded your status and you should now be able to edit posts as required.
Like anywhere else in life, the higher your status the more privileges you earn here.
Should be all good for you as of now
Old Sep 15, 2012 | 05:05 PM
gunnar_xj6's Avatar
Thanks I will write an intro, I was granted the edit button now.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Saturbo
Sep 8, 2015 07:35 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
