Mark V - X 420G 1948 - 1970
VIN# location please
Old Nov 17, 2025 | 06:57 AM
HoraceMorris's Avatar
Default VIN# location please
1966 MK X
Vin # location <<<<<<
Seeking to register car
Have plate with body,engine,transmission etc
Thank you for assistance
Old Nov 17, 2025 | 07:06 AM
Bob_S's Avatar
The chassis number is the vin number
Old Nov 17, 2025 | 09:20 AM
Default Vin# location please
I have the plate with car#, body#, engine#, trans#
1 Is the "car#" the actual vin# ?
or
2 Is the actual vin# located somewhere else?
I'm trying to register the car but it is not pulling up when the inspector runs the numbers from the plate
Old Nov 17, 2025 | 10:02 AM
Bob_S's Avatar
I believe it’s the car number. It should be 1Dxxxxx. There may be a P in front of the 1D for power steering.
Old Nov 17, 2025 | 01:19 PM
Bob_S's Avatar
For some reason Jaguar called the ViN different things at different times. Sometimes chassis # other times car#. Who knows why !
Old Dec 30, 2025 | 08:21 AM
voretop's Avatar
From what I’ve seen with older Jaguars, it can definitely be confusing. Usually, the car# on your plate is the VIN, but sometimes they used chassis# instead.
Old Jan 3, 2026 | 03:30 PM
voretop's Avatar
You can also double-check it by running the car#/chassis number through a window sticker by vin https://carfast.express/en/window_sticker service. Those reports often show how the factory labeled the number (car#, chassis#, etc.) and original specs, which can help when inspectors can’t match it.
Old Jan 4, 2026 | 08:28 AM
jerry_hoback's Avatar
Ive found that the vin check sites (or apps) wont work with anything less than the 17 digit vins. On my s-types the vin is the upper left on the plate under the hood, and that space is indeed labeled "Car No.".
Old Feb 5, 2026 | 10:44 AM
ferterveras's Avatar
First, check the requirements in the region where you plan to register your car. In some places, a manufacturer's plate and proof of year of manufacture are sufficient, while others may require additional inspections or an expert assessment.
luke kim
XF (X260)
Apr 13, 2022 10:10 PM
mikega
Jun 4, 2021 11:59 AM
s.weissone
Nov 16, 2017 01:59 PM
hafren
XE ( X760 )
Oct 10, 2016 05:17 PM
harry
Aug 27, 2012 04:29 AM
