electrical connection mk2 3,4 with dg 250 automa
Old Mar 24, 2018 | 10:11 AM
udo's Avatar
udo
Default electrical connection mk2 3,4 with dg 250 automa
hello i cant find a diagram of this situation
there are two solenoids
Old Mar 24, 2018 | 03:35 PM
TilleyJon's Avatar
Hi Udo, and welcome to the forum
Are you looking for a wiring diagram ? You have given very little information.
Old Mar 24, 2018 | 04:58 PM
udo's Avatar
udo
yes i have diagram but for a normal gearbox
the automatic is a dg 250 with two solenoids at the end how to connect them electrical
car is a mk2 3,4 l
Old Mar 28, 2018 | 02:08 AM
Homersimpson's Avatar
You need to get hold of a wiring diagram for the car, you may be able to download one from the internet but if not then get a Haynes manual from e-bay/amazon which will show you this.
The two solenoid on the DG250 are actually one solenoid and one pressure switch.
The solenoid (the long thin unit bolted on) operates the intermediate speed hold, effectivly this locks the transmission in second when you operate the switch on the dash.
The other unit (round screwed in switch) measures the pressure when the car is stationary and in conjunction with a switch on the carb/throttle linkage operates the anticreep solenoid which holds the rear brakes on when you stop and prevents the car creeping forward.
Old Mar 28, 2018 | 02:14 PM
TilleyJon's Avatar
Here is the wiring diagram for a MK2, the auto box wiring is shown on the right hand side half way down the page.
S Type wiring diagram also if it helps as per Jose's post
File Type: pdf
File Type: pdf
Old Mar 28, 2018 | 04:52 PM
Jose's Avatar
does the dash have a SPEED HOLD switch? if yes, one of the solenoids is the SPEED HOLD SOLENOID. The other solenoid could be the ANTI-CREEP device, not sure about that last one.
so you could check the S type's wiring diagram since it came with the DG250 tranny.
michael gosling
30
Aug 24, 2017 12:57 PM
rjrmdarby
Dec 16, 2016 09:45 AM
Jaguila
Feb 3, 2014 01:04 PM
Trick Freestones
XJ40 ( XJ81 )
Jun 2, 2011 09:54 AM
MotoGuzzi
XJ40 ( XJ81 )
Feb 16, 2010 11:03 AM
