Heres my leak
Old Jan 18, 2019 | 08:41 AM
chris tian's Avatar
Default Heres my leak
Im having trouble naming this cooper part I circled.
Any help would be appreciated. The shop Im trying to order it from cant help....
Thank you.
Old Jan 18, 2019 | 09:51 AM
Glyn M Ruck's Avatar
See here.
https://www.jaguarforums.com/forum/m...cation-209831/
That is the cam feed Y pipe.
You likely only need new copper washers on all banjo joints.
Part number for copper washers. C4146
Part number for cam feed pipe if needed. C25619
Old Jan 18, 2019 | 10:22 AM
Jose's Avatar
they call them Banjos.
Old Jan 18, 2019 | 10:53 AM
Correct Jose as I said above. Christian. Each of the 3 terminations of the Y pipe has a banjo fitting. 6 copper washers required to seal them all. 2 per banjo joint. These banjo joints are not separate they are part of the cam oil feed pipe. Check the pipe for cracks if the new copper washers do not fix the leak.
Old Jan 18, 2019 | 11:33 AM
chris tian's Avatar
Thank you sirs !!
Old Jan 18, 2019 | 12:12 PM
Jose's Avatar
there is a thread here about the thickness of the washers.
the poster could not cure the leak even with new washers until he found out the washers he was using were too thick.
worth investigating that thread.
Old Jan 18, 2019 | 01:06 PM
S-Type Owner's Avatar
You can also soften harder alloyed copper washers by annealing them,,should they fail to seal properly. This was a problem with aftermarket seal rings used at fuel filter banjo fittings back in the day (think W116 and R107 Mercedes cars).
Old Jan 18, 2019 | 01:23 PM
Is there another thread here other than the one I posted in my first reply? I would like to read it. You can use Stat O Seal washers but some of them are too thick. I don't even have sweating using NEW C4146 copper washers.
Old Jan 18, 2019 | 02:46 PM
TilleyJon's Avatar
Get the correct washers with squash rings as per picture in Jose's posts and the other thread Glyn linked to.
Oh and just for interest Chris tian the washers are copper, the Banjo in your picture is brass, some of the new ones are plated, but I actually don't know what they are made of, in my opinion the Brass ones seal better than the plated ones, it may just be coincidence but that's my experience.
Old Jan 19, 2019 | 05:18 AM
chris tian's Avatar
Thank you, thank you !!
I managed to find them, All 6 of them are on their way with new radiator hoses too
Old Jan 19, 2019 | 10:26 AM
Good news! The C4146 copper washers with squash rings are really designed to be used once & replaced every time you break the joint which should not be very often.
TheBrightKnight
Jul 23, 2012 09:14 PM
YacobX
Photography
May 28, 2012 01:48 PM
jagxkrtoofast
Feb 24, 2012 07:45 PM
etaent
Feb 18, 2012 05:08 AM
andy303
Nov 14, 2011 06:39 PM
