How to Measure the Rear Springs.
Old Jul 10, 2023 | 04:19 PM
sportfan's Avatar
Default How to Measure the Rear Springs.
I have a 1962 Mk 2 that while I'm doing rear suspension work on, I wanted to check out the springs. The factory service manual has a drawing showing how to take a measurement to see if the springs are within specs. My question is are you to take the measurement on a bare main spring or the complete spring assembly? The drawing just shows the main spring.
Old Jul 10, 2023 | 05:22 PM
Glyn M Ruck's Avatar
For a Mk2 owner to answer:
Old Jul 10, 2023 | 05:45 PM
sportfan's Avatar
Thanks for your reply, Glyn. What I'm trying to find out is about the arch of the springs. The drawing in the factory service manual shows a line drawn from the center of the rear bolt hole of the main spring to the flat on the opposite end of the spring. In the drawing it just shows the main spring leaf only and not a complete spring assembly. So, my question is do I need to take the springs apart and measure just that main leaf or measure a complete spring assembly? I have never driven this car and don't know if the springs need to be re-arched.
Old Jul 10, 2023 | 05:56 PM
Sorry I was not finished. Now your question will make more sense. A picture paints a 1000 words.
Old Jul 10, 2023 | 06:07 PM
I would say that the entire spring assembly should be measured for comparison. BUT I am an IRS man. What does one leaf mean if others are buggered or mismatched? (unless I misconstrue the concept of free camber)
Old Jul 10, 2023 | 06:32 PM
Refresh page for edits.
Old Jul 10, 2023 | 08:39 PM
sportfan's Avatar
I really don't have any reason to believe that any parts were mismatched or buggered up. I don't think the springs have ever been taken apart before. I tend to believe that the drawing means that the measurement be taken on a complete spring assembly and not just the one leaf. I would like to be sure.
Old Jul 10, 2023 | 10:10 PM
Bill Mac's Avatar
I have measured this free camber a number of times with the springs apart and have never found a spring out of tolerance.
I now consider it a WOFTAM (a Waste Of Flaming Time and Money)
The critical parts in the rear end of MK1/2 are the rubbers.
If the rear end is sagging it will be the body mount rubbers, particularly the front mount pad and centre mount rubber.
The really critical parts for handling are the torque arm rubbers.
The torque arms keep the axle located correctly to the body. Bad rubbers will allow the axle to wander.
The panhard rod system does work but do check its body end mount for cracks etc. A very common fault
Old Jul 11, 2023 | 01:11 AM
sportfan's Avatar
Thanks for the advice. I took one of the springs apart and the main leaf by itself is out of tolerance. The spring assembled was within tolerance. I didn't find any cracks around the Panhard rod body mount but, I went ahead and braced it up anyway. The rod itself was bent, which I've read is common. I got the rod straight within.010." I found and repaired cracks in the body around the right-side upper shock mount and on the left side fender well where the exhaust mounts. I have all new poly bushings for all the rear suspension. All of the OEM bushings and mounts were shot. I really don't know if the car was sagging or not. It had been in storage for 20 years and the tires barely held air long enough to get it up on a trailer. I'm not going to do a concours type restoration on car but, while I'm this far into it I'm going to tear down, bead blast, and paint the springs.
Old Jul 11, 2023 | 03:55 AM
Thanks Bill ~ I was hoping you would chime in. You know Mk1 & Mk2 backwards. There is a factory bulletin to dealers to reinforce the Panhard rod mounting to the body. On early cars (Mk1) it used to pull right out of the body. They were still learning weak spots in the monocoque bodywork. I have it somewhere but too much trouble to find (my filing system sucks). We know about it and that's all that matters.
Old Jul 11, 2023 | 07:37 AM
sportfan's Avatar
I have a copy of N 20 service bulletin about bracing up the Panhard arm mounting area. I couldn't find a drawing on the factory brace so, I just made one and welded it to the frame/unibody.
Old Jul 11, 2023 | 04:48 PM
Ah good! so all done.
Old Jul 11, 2023 | 05:37 PM
Peter3442's Avatar
To add to Bill's comment on rubber, the rubber pads between the leaves of the spring are important in maintaining the set of the assembled spring. They deteriorate and disappear. The centre support of the spring on the left side of the car (without the Panhard rod mount) can collapse and cause the car to sit low on that corner. I've modified the one that will go on my car so that it is a mirror image of the one on the right side. The whole arrangement of the spring hangers is a terrible mud trap and suffers corrosion damage. The design of the rear suspension of the Mk2 is clever in many ways, even brilliant compared with what most were doing in the mid-1950s, but it has its weaknesses.
Old Jul 12, 2023 | 07:46 AM
sportfan's Avatar
One thing I found after taking the right-side spring apart was it is arched .125" more than the left spring. After both springs are reassembled the one with the most arch will be installed on the left side. Does anyone know of a source for the rubber buttons that go between the leaves of the spring? If I don't find them for sale somewhere I'm going to look into buying a do-it-yourself poly bushing kit. I can machine a mold then and cast them myself. Thanks for all the help everyone.
Old Jul 12, 2023 | 08:13 AM
Peter3442's Avatar
I think that I cut the buttons out of some rubber sheet. It was a long time ago.
If the car doesn't sit level and you are fairly sure it's due to the rear springs, it's possible to make some adjustments at the reaction plate (the opposite end of the spring from the axle). Add a spacer between the plate and the spring to raise the car or washers between the plate and the body to lower it. Don't do anything until the springs have settled as leaf springs have a lot of internal friction to shake down.
Old Jul 12, 2023 | 08:22 AM
Peter3442's Avatar
I noticed that SNG Barratt has a lot of rear suspension rubber and poly bits, they may have the button spacers. Also David Manners has complete springs that look as though they could be some of the factory original stock that he bought 50 years ago.
Old Jul 12, 2023 | 08:07 PM
Bill Mac's Avatar
Other small snippets of information ref. MK1/MK2 rear springs.
Many years ago, I got our local MK1&MK2 Jag club members to check the rear end "ride height" of their cars.
This was done on the basis of nobody in the car and the distance was from the centre of the boot (trunk) lock to the ground. We ignored the fuel quantity which could vary by 70 lbs.
The average turned out to be 18 1/2 to 19 inches.
One of my MK1s came out at 16 inches and was "dragging its bum" so it did require attention.
If you see a scrape mark on the rear cover of the differential it means that the axel is moving around and is a sure sign of torque arm bushes being "shot" and the diff rubbing onto the car body.
I have seen this on 4 cars and on one car had worn a hole in the diff cover requiring a welded patch repair.
Yellow series3
Aug 11, 2019 03:15 PM
multistrada74
Oct 8, 2015 08:58 AM
felinecat
E type ( XK-E )
Jul 31, 2015 01:43 PM
J-Rock
Oct 19, 2014 10:56 AM
etaent
Jan 29, 2012 12:34 AM
