Interior Door Panels - Where Can I Get Panel Attachments?
Old Aug 22, 2015 | 02:27 PM
1964Daimler's Avatar
Default Interior Door Panels - Where Can I Get Panel Attachments?
Here's a pic of the rear passenger door.
All the panels are off all doors, just like the one in the picture.
I've started to re-make the door panels from fiberboard.
The old ones were rotten away, so I'm cannibalizing pieces from all the doors to make a single pattern for both the front and rear doors, respectively.
But I need the pieces that attach the interior panels to the door.
Where can I get a bundle of these?
I've gone to some auto shops and asked.
I get the RCA Dog in front of the phonograph look.
Went to a local hardware store. One guy recognized the piece I brought in and said it came from a Fiat ( Same type of fitting?).
So advice on the panel project requested!
Attached Thumbnails Interior Door Panels - Where Can I Get Panel Attachments?-picture-019.jpg
Old Aug 22, 2015 | 05:28 PM
JeffR1's Avatar
You mean these things ?
SNG Barratt - The Ultimate Jaguar Parts Specialist
If this is what you're after you can go to an upholstery shop that does car interiors with a picture, they may have them a little cheaper.
Old Aug 23, 2015 | 11:11 AM
redtriangle's Avatar
Whilst you have the panels off, check the inside of the doors for rust.
If the panels were rotten, good chance rust has attacked the base of the door and also the window frame post fixings, esp as Jaguar in their brilliance fitted felt pads between the post and the door skin which becomes a sponge when wet and promotes the cancer.
Water also gets trapped between the bitumen sound deadening panels stuck to the inside of the skins.
Old Aug 23, 2015 | 02:36 PM
Good point!
I'll check. If there is rust, what to do?
Any rust inhibitor sprays? WD40?
Also: should the interior mechanisms within the door be sprayed with penetrating oil?
If so, what types?
Old Aug 23, 2015 | 02:54 PM
Yep!
That be it!
That's why I come here Jaguar Forums!
The knowledge I need!
I'm astounded at the quick responses and the total number of views per posting!
Old Aug 24, 2015 | 11:50 AM
littlelic69's Avatar
Originally Posted by 1964Daimler
Good point!
If so, what types?
When I bought my Daimler the drain holes in the bottom of the doors had been blocked and engine oil poured in! Unfortunately, rain water easily passes the window seals and collects in the doors. You can imagine the mess and resulting corrosion inside the doors. I used a liberal coating of HAMMERITE KURUST. This chemically attacks the rust and forms a stable layer helping to stay any further damage. Now thick grease is a good antirust treatment - I like copper bearing grease. It is messy! Ensure the drain holes remain clear!
Old Aug 25, 2015 | 01:20 AM
Here are pictures of the door panels that came with the car.
Both front and rear were in this condition.
I basically put together two of the panels to make one panel as a pattern.
Will cut the fiberboard and fit. It doesn't look too good, though...
But it's what I have to work with.
And ou can see the velvet that was mentioned in earlier posts...
Attached Thumbnails Interior Door Panels - Where Can I Get Panel Attachments?-door.jpg   Interior Door Panels - Where Can I Get Panel Attachments?-door2.jpg   Interior Door Panels - Where Can I Get Panel Attachments?-door4.jpg   Interior Door Panels - Where Can I Get Panel Attachments?-door-3-.jpg
Old Aug 25, 2015 | 04:43 AM
Talking
Those remnants will not be of much use as patterns for new panels.
I tried to replicate my LH front door panel & after spending hours stuffing around, gave up & left it to the experts.
Of particular note, the front door panels extend about 1/2" beyond the leading edge of the door, so that they meet the Furflex on the door frame resulting in an effect seal against drafts. I did not realise this until after offering up my replication. If I wasn't such a novice, I would have checked the fit on the driver's side first!
The other issue is the holes in the panel for the spring clips which press into the door itself. These are off-set to suit the clips, and have to be precise so that they all line up correctly thus allowing the panel to press into position correctly. The water affected wood panel (like yours) is not in the best state to use as a stencil.
Also, the fibreboard has to be the exact same thickness for the spring clips to fit properly. They are design to rotate a little to assist with insertion in the door holes. I used 4mm plywood (too thick) & got into allsorts of difficulty.
Remember also the vynil covering has "welded" lines in its pattern, so to maintain originality, these have to be replicated. Not sure how any DIYer would be able to do that.
For all the above reasons, I recommend outsourcing this job.
As Clint Eastwood would say, a man has gotta know his limitations!
Old Aug 25, 2015 | 04:42 PM
Fraser Mitchell's Avatar
It is possible to buy these panels finished ready-to-fit, but they're not cheap, I'm afraid. Suppliers are mainly UK-based.
Old Aug 25, 2015 | 05:46 PM
SNG Barratt USA's Avatar
Former Sponsor
We supply them in the US. Made to order, feel free to call for more information.
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
trosty
26
Dec 18, 2022 06:40 PM
GordoCatCar
Jan 2, 2017 01:10 PM
obwoodie
Sep 3, 2015 07:45 PM
