John Marsh
Old Jan 24, 2021 | 07:09 AM
John Marsh's Avatar
Default John Marsh
I used to own a 1965 Mk11 3.8 Auto with column change gear shift, I have recently seen one with a floor change, can anyone tell me if this was an option or when Jaguar changed the gear shift. thank you
Old Jan 24, 2021 | 07:18 AM
Glyn M Ruck's Avatar
No it was not an option but I've seen XJ6 floor changes modded to fit or later transmissions fitted.
Old Jan 24, 2021 | 07:22 AM
Jose's Avatar
an automatic MK-2 with a center console automatic transmission shifter?
no, never. Not factory. Probably adapted from a XJ-6 which have center console automatic transmission shifters
Old Jan 24, 2021 | 07:38 AM
Jose's Avatar
XJ-6 center console or "floor" shifter,
is this what you saw? Then the car probably has a BW65 or BW66 transmission, even a GM 400 R is possible using the same shifter.
Old Jan 24, 2021 | 08:39 AM
Some Mk2 Auto's modded to floor shift.
Old Sep 3, 2021 | 02:31 PM
rdssdi's Avatar
Appears that the center console was also modified. The console is shorter. No heat vents at the end as well as looks much taller than original. I believe Vicarage also used a console mounted gear selector but as I recall it sat on an unmodified console. Could anyone post a Vicarage modified MK 2 with this selector? Thanks.
Any suggestions on doing this modification. I am considering now. Thanks.
Bob
Old Sep 3, 2021 | 07:13 PM
Most Vicarage cars are manual.
These are the best pics I have of Vicarage auto consoles.
Old Sep 4, 2021 | 09:07 AM
Jose's Avatar
I think the pictures above show a Series 3 XJ-6 automatic shifter normally used with the BW66 automatic transmission and a XJ-40 automatic shifter used with the Getrag ZF automatic transmission that has a Manual "Sports" setting. I have no clue what Vicarage ever did.
As far as the center vent for the rear seat, they were never very useful, more cosmetic than functional as not much air comes out of it in the MK-2 or the S type or the 420 or the MK-X or the 420-G. No loss there.
Treozen
25
May 27, 2023 06:49 AM
Ronald david
Jul 22, 2020 05:37 PM
Bcrary3
Apr 29, 2015 09:47 AM
Disco stu55
Aug 28, 2011 02:04 PM
SeismicGuy
Nov 22, 2008 11:41 PM
