Need 1 Mk2 parking brake pad
Old Nov 7, 2014 | 05:39 PM
dmericas's Avatar
Default Need 1 Mk2 parking brake pad
I just determined that the reason my handbrake is wimpy is one of the brake pads is missing. It looks like the friction material detached from the backing plate.
The brakes were completely rebuilt a few thousand miles ago, so the other 3 pads and all of the hardware bits are in essentially unused condition.
Does anyone happen to have a newish spare pad for a self adjusting parking brake? If it makes any difference, it's the outer right side pad.
Thanks.
Old Dec 8, 2014 | 10:33 AM
blurooster's Avatar
just removed the rear end from my 62, will see if the pads are good, get back to ya
Old Dec 8, 2014 | 12:18 PM
dmericas's Avatar
Thanks, but I went ahead and purchased a full set. The other three on my car are nearly new, so now I have three extra sitting on the shelf for when someone else needs just one.
Old Jul 17, 2017 | 02:49 PM
blackjack1's Avatar
Hi Guys,I had a very similar experience on me old V8/250? Two of the linings came off-clean as a whistle after I dropped the pads on the ground,I got a set off EBay and instead of being handed 2&2 I got3 of one side and 1 of the other-Great! So I'd grab at the opertunity to buy one correct pad used or new but I'm in the UK do you think the purchase&P/P from the USA would end-up costing me more than buying a set over here? Regards Paul.
Old Jul 17, 2017 | 03:05 PM
TilleyJon's Avatar
I will have a look, I may well have a decent handbrake pad about, which side are you looking for ? You can have it if I have one of any use.
Old Jul 18, 2017 | 03:59 AM
blackjack1's Avatar
Default Handbrake pad x1
Hi Tilleyjon,thats very good of you-im at work at the moment,tonight il have the wheel off and confirm for you-id hate to end up with 4 of one type and 1 of the other!,if i remember rightly i fitted one of the incorrect ones so i atleast had a handbrake but your only using part of the ligning as the slope on the top of the pad is going the wrong way so looks wrong to,anyway il get back to you- All the best Paul. Just to add-im pretty sure it was the inboard pad on the offside wheel but i better check-it was a year or two ago when i fitted them?
Old Jul 18, 2017 | 04:49 PM
blackjack1's Avatar
Hi Tilleyjon,yes the problem pad as I thought is inboard on the offside wheel,if you have anything even a worn one would be better than the wrong handed pad-it works ok and would probably get away with it for the MOT as it shouldn't go on the rolling road to check its performance,I think they should find a slope somewhere and check it holds the weight of the car ok,but when you take the wheel off and look from above it leaps out at you,anyway il leave it with you and greatfull for you taking time to have a look-all the best, Paul.
Old Jul 19, 2017 | 12:52 AM
TilleyJon's Avatar
Just so I don't get confused, it's one of the left hand ones in this pic that you need ?
Old Jul 19, 2017 | 03:18 PM
blackjack1's Avatar
Default 1 handbrake pad
W
Hi Tilleyjon-your rite it is confusing, iv just wipped the wheel off again and taken a couple photos to be sure against the picture youv sent? As you look at your picture i need the one on the right please, I would like to pay something+p/p im happy not to have to buy another set.How does one go on about giving out e-mails,addresses etc on the forum? And would you like me to pay via pay-pal?
Old Jul 20, 2017 | 12:43 AM
TilleyJon's Avatar
I will see what I have, you can PM me your email, click on my name, and from there you can PM me.
Old Jul 20, 2017 | 01:22 AM
TilleyJon's Avatar
I've found a pair, so PM your address etc and I will get them in the post, you can't go wrong if you have both !
Jon
H20boy
Dec 24, 2024 03:23 PM
SeanU
Sep 13, 2015 02:45 PM
sawduster
Sep 11, 2015 10:02 PM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
