Number Tag Question
Old 02-16-2018, 04:10 PM
tedwone's Avatar
Default Number Tag Question
While working in the trunk (boot) area of my car this morning I discovered a small aluminum number tag that is held in place with two screws. The number on the tag is different from the car number or body number. It has an "M" followed by six numbers. The tag is located near the fuel pump side of the trunk. Does anyone know what this number signifies or is related to?
Old 02-16-2018, 05:19 PM
Jose's Avatar
Received 2,434 Likes on 1,832 Posts
could it be the aluminum tag from the fuel pump? SU fuel pumps come with a tag.
Old 02-16-2018, 05:21 PM
George Camp's Avatar
Tedone I think you have found the inventory tag from pressedsteel!
tedwone (02-17-2018)
Old 02-17-2018, 05:59 PM
tedwone's Avatar
Thanks George. Was that common practice back in those days? The tag was screwed to a vertical section of a panel that is part of the trunk (boot) floor and is located near the left rear of the trunk. I was just curious because the number doesn't seem to be related to any other numbers on the car. Once the restoration is completed, I will put the tag back where I found it.
Old 02-18-2018, 04:28 AM
TilleyJon's Avatar
Could you post a picture Ted, very interesting.
Old 02-18-2018, 06:08 AM
Ted if you look in the rear seat pan you should also find a metal plate from Pressedsteel with all of their patents and such.
TilleyJon (02-18-2018)
Old 02-18-2018, 06:28 AM
MK2's Avatar
MK2
MK2 is offline
Here you go, Jon:
Attached Thumbnails Number Tag Question-1c894ff7-1be8-4087-be04-c52bd7b4cd75.jpeg
Old 02-18-2018, 10:06 AM
tedwone's Avatar
The photo posted by MK2 is the tag and location I discovered. It is more of a curiosity and George seems to have explained what it is all about.
Old 02-18-2018, 02:48 PM
TilleyJon's Avatar
Ah, I have found a couple of those, and I wondered what the plate under the seat was, it was a bit shot with cadmium corrosion on mine so I could not read it, but put it back for historic interest. Thanks guys
Doctor Olds
XK120 XK140 XK150
11-03-2019 06:31 PM
Fast71SS
12-30-2017 04:23 PM
savhomer
22
06-06-2013 06:11 PM
achysklic
51
03-28-2011 01:53 PM
peewee
08-05-2008 02:00 AM
Quick Reply: Number Tag Question
