Rear engine mounting
Old Mar 9, 2024 | 07:19 AM
Popstacle's Avatar
Default Rear engine mounting
Good day.
This is the Rear Engine Mounting Coil Spring. I am not sure what the plastic part is. Is it the retainer for the coil spring? I don't seem to find a replacement on SNG Barrat.
Old Mar 9, 2024 | 02:35 PM
Glyn M Ruck's Avatar
Default Rear engine mounting.
Spring with cup on either end & rubber bush for rear vertical shaft in back engine/GB mounting.
Old Mar 9, 2024 | 02:43 PM
Genuine Service Manual
http://www.jagstyperegister.com/imag...vicemanual.pdf
Old Mar 9, 2024 | 02:56 PM
Barratts only seem to have bits & pieces in stock. Try David Manners, Norman Motors, Martin Robey. Note there are a number of springs dependent on your configuration, Auto, Manual, Manual/OD etc. ~ Rubber cup top & bottom of spring. Rubber bush on shaft.
Old Mar 9, 2024 | 03:08 PM
Popstacle's Avatar
Thanks Glyn. That is the way I have it as well, a cup on each side and a bush. I was just wondering because in my car there is a larger plastic part inside the spring, I assume it some sort of replacement for the bush as there was none. I'll replace the correct parts now.
Old Mar 9, 2024 | 04:28 PM
The Bush is one thing Barratts do have.
Old Mar 9, 2024 | 05:04 PM
This is the early mounting for manual or automatic at one time. Stay well away from it. See temporary assembly pin & washer.
Is for assembly purposes only.............. If you leave them attached you will suffer from severe NVH issues. The same applies to the new mounting that you will have. See the hole in my shaft above.
Old Mar 10, 2024 | 12:40 AM
Jagboi64's Avatar
It seems counterintuitive, but the rear of the transmission just floats; it's supported on the spring and stays there only by it's own weight.
leaddog11
Feb 14, 2023 10:52 AM
Quadcammer
Jul 15, 2022 01:15 PM
Lar's
Feb 9, 2016 04:58 PM
JaguarJoey
Oct 15, 2014 02:26 PM
