S type skin thickness
Old May 25, 2015 | 01:24 PM
bendougy's Avatar
Default S type skin thickness
Can anyone advise the gauge or thickness of the material for the S Type 65 skin or panels
Old May 25, 2015 | 06:13 PM
primaz's Avatar
I am not sure but can tell you that the S-type fenders are crazy strong as I had to use a frame puller with two chains on each rear fender just to get a minor 1/2" bow on the rear fenders to ensure there was no tire rub when I did the body work. These cars are made like a tank.
Old May 26, 2015 | 05:47 AM
Fraser Mitchell's Avatar
Unfortunately this is not commonly published information. The various steel panel thicknesses are measure using the Standard Wire Gauge system, (SWG). The UK supplier of Jaguar panels, Martin Robey, may be able to help you.
Martin Robey
Old May 26, 2015 | 04:19 PM
bendougy's Avatar
Is Martin Robeyy the only manufacture of jag panels world wide
Old May 26, 2015 | 09:54 PM
primaz's Avatar
Do you have body damage or ? What is the reason for your question?
Other than the doors, hood, trunk the rest is a one shell. You can get used parts for an S-type and for body sections that are not the above sectional parts you can find wrecking yards whom may cut out the section your are missing.
Old May 27, 2015 | 07:46 AM
bendougy's Avatar
My car has had panel damage bogged over. The creases are to tight I think to straighten and not a lot of s type wrecks in Darwin Australia. Looking at my options ie costs to see if I can replace panels. Only need front of LH fender ans sills. The rest I can cut and paste.
Old May 27, 2015 | 04:38 PM
As far as I know, Martin Robey is the only manufacturer of panels for the classic Jaguars now. I think they do ship to Oz, but bear in mind only a small subset of the original panels are made, namely those that tend to rust out.
What I do know is that the sill sections are a far thicker gauge than the other panels, 16 swg I believe.
Old May 27, 2015 | 05:46 PM
John Francis's Avatar
Picures of damaged panels would help. There are many "panel beaters", "metal shapers" in
Australia that could be of some help possible, see All MetalShaping - Powered by vBulletin
Old May 30, 2015 | 06:57 PM
Jose's Avatar
clean the sides of the panel on both sides and measure with a caliper.
Old May 31, 2015 | 07:29 AM
redtriangle's Avatar
I did that on a piece of scrap from a S type door skin (I never throw anything away!)
Measured about 0.039" or 1.01mm on my calipers. According to Wiki, that equals 19SWG.
Hope this helps!
Old May 31, 2015 | 09:18 AM
Jose's Avatar
I think the door skins are always thinner than the rest of the body panels, because the door skins need to be "pliable" or "bendable", whereas the wings and other "permanent" panels need to be sturdy.
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
