SU fuel pumps
I purchased tubs full of S type, XJ-6, and XJ-S parts.
I found what may be two brand new boxed SU fuel pumps which I want to install in my S type. The date in the Instructions Sheet is 2009.
does anybody know to who I can send them in the USA to get them tested before installing them?
Thanks.
Thanks.
I don't know how!! I mean, without connecting fuel lines and all that stuff, which I want to avoid, testing them with 12volts no problem, but if you've ever removed and reinstalled a fuel pump in the S type, you would understand why.
Some fuel in a container, connect up some fuel line to either side and fit a pressure gauge to the out line to check pressure. Then apply 12V .
I tested them, one almost flew out of the bench when I applied 12 volts.
the second one is dead, well no ticking.
